Thread: ZR1s or GS on a Formula
03-21-2006, 08:36 PM #1
- Texas
White- 99 Pontiac Formula
My Formula is lowered with Eibach Springs and running Koni Yellow Shocks
I know will have to do the BFG mod to my inner fender walls in the rear (been reading)
but I was wondering since I have a Formula can I use the ZR1 offset rather than the GS offset and not have to roll my fender lips?
or do I need to roll my fender lips with either cause of my car being lowered?
or will the ZR1 offset even fit with or without the fender lip rolled?
also can anyone here suggest a shop that can roll the lip in Dallas, Texas?
I have been having no luck finding a Camaro/Firebird/Corvette Custom Shop in Dallas
also where can I find center caps? SLP wants 35/cap
and who is a good maunfacturer of ZR1 wheels?
I have seen OE Creations, AFS, and a few others
also will the SLP replacement bumpstops work with the ZR1 wheels?
http://www.slponline.com/view_product.asp?P=80046Last edited by kny3twalker; 03-21-2006 at 09:25 PM.
03-23-2006, 02:11 PM #2
- Jun 2002
- Montreal, CANADA
zr1 offset will make the wheels stick out even more than the GS.
You will have to at minimum fold the lip, if not flare it.
Mine are GS offset... pix in link in signature.
Pix are with Eibach Prokits and Konis.Eugenio_SS
03-23-2006, 11:45 PM #3
- Texas
did you clear coat your wheels are polishing them?
I was thinking about the AFS polished and having them powder clear coated
what company did you buy your wheels from? (brand of wheels)
where did you get your center caps?
how did you handle your bumpstops?
and do I need the adjustable panhard bar?
and on a side note, what did you do about rubbing up front with the 11" wheels?
and thank you
03-24-2006, 07:20 AM #4
That SLP price is for a set of 4 caps. I bought a set of ZR1 chrome 9.5x17 56mm offset on ebay for $550 but they came with Corvette caps. Got chrome bowtie caps from SLP.
Bowtie good! Blue oval not so good! Bob in the PRK
03-24-2006, 07:50 AM #5
- Jun 2002
- Montreal, CANADA
Originally Posted by kny3twalker
Didn't get the polished ones, since behind the spokes (polished and chrome version) are rough aluminum, not smooth surface which is hell to clean with all the brake dust.
What rubbing in the front ?
the rubbing only happened in the rear, fronts were plug and play.
You can easily put a wider wheel and wider tires in front with no issues... some have 17x12 w/ 335s on the front.
For the bumpstops, I cut them in half (removing the half on the outer part), so it clears the wheels.
adj PHR helps, but getting a rod-end one will help you more.
best way to adjust it is to remove the springs and adjust it as you raise the rear-end into the wheel wells... since rubbing occurs when spring is compressed.Last edited by Eugenio_SS; 03-24-2006 at 07:52 AM.
03-24-2006, 08:30 AM #6
- Texas
and what's the rod-end one? (not familiar)
oh and if you could not tell, I have not done in spring installs either myself
I bought the wheels from AFS, bought the painted ones, and then stripped them and polished them.
and thanks again for taking the time to answer my questions
That SLP price is for a set of 4 caps. I bought a set of ZR1 chrome 9.5x17 56mm offset on ebay for $550 but they came with Corvette caps. Got chrome bowtie caps from SLP.Last edited by kny3twalker; 03-24-2006 at 08:32 AM.
03-24-2006, 08:31 PM #7
- Jun 2002
- Montreal, CANADA
Once that is done, take a jack and raise the rear-end so the wheels go in deep inside the wheel well.
Here is an example of a rod-end good quality piece:
http://www.unbalancedengineering.com/Camaro/PHR/
pleasure is all mine to try to help as much as i can.
03-24-2006, 11:45 PM #8
- Texas
having the car raised and the rear end hanging, you can easily remove the uncompressed springs by hand.
springs in the front require the compressing tool since they are mounted on the shocks... the rear ones aren't... it's just the spring sitting on the rear and having a rubber insulater on the top.
during the repair he kept telling about how difficult springs were, I guess he was referring to the front
LOL
There are mainly 3 types of PHR... rubber, polyurethane and rod-end (same as helm-joints).
what about the rod end PHR, helps more?
just seems extreme in my situation
again thanks, this site makes projects more feasible
03-25-2006, 03:56 AM #9
- Jun 2002
- Montreal, CANADA
The PHR I would not go polyurethane... when turning, the PHR will prevent the rear-end from moving left to right.
With the rod-ends, it lets it do its work properly with freedom of movement.
Poly and rubber will bind, but poly will bind the most since it's a harder material... and that will hinder your handing, not to mention that the bind won't let the PHR do its work so well, you then increase the chances of rubbing.
It's a bit more expensive, but at least you only do it once.
If you do it, make sure you get it from a place where the rod-ends are of great quality.
I could think of 3 and not many more (UnbalancedEngineering, LG, TrackbirdEngineering)
03-25-2006, 07:37 AM #10
- Texas
try them, thats the company I was referring to above in my previous post
and thanks for the explanation
03-25-2006, 08:38 AM #11
- Jun 2002
- Montreal, CANADA
03-26-2006, 01:29 AM #12
- Texas
The high quality QA1 spherical rod ends provide for "bind-free" handling performance. The solid connections will increase road noise.
All of our spherical rod ended components come equipped with QA1 extra high strength, chrome moly rod ends with Teflon®/Kevlar® self lubricating race. When shopping around for spherical rod ended components, do not shop on price alone. The lower grade rod ends (which are much cheaper) will not hold their tolerances like the premium QA1 rod ends we utilize, this will cause substantial amounts of noise in a short time. We have had to increase our prices, but it is money very well spent in the long run, these rod ends will last a very long time. The rod ends supplied on our components are QA1 ENDURA 2000 Series (XMR12/XML12).
Black ZR1s
By bad4ss in forum Wheels and TiresReplies: 3Last Post: 03-08-2011, 08:02 PM -
Black ZR1s
By BirdCountry02 in forum Wheels and TiresReplies: 6Last Post: 10-19-2009, 10:09 AM -
FS: 02 WS6 and ZR1s
By CptMidway in forum Parts For Sale / TradeReplies: 6Last Post: 11-22-2008, 06:38 AM -
LTT..my zr1s
By QtrWhore in forum Parts Wanted / TradeReplies: 0Last Post: 07-12-2008, 12:07 PM -
Black ZR1s
By HNIC57 in forum Parts Wanted / TradeReplies: 1Last Post: 01-15-2007, 11:45 AM
