Results 1 to 16 of 16
    Factory Freak Mikat1's Avatar
    Sep 2009
    Upper California
    Artic
    2002 Z28
    bent pushrod/misfire?
    Howdy folks. Just curious if a bent pushrod would cause a misfire. My car is missing pretty hard going through the gears in full throttle. I have recently replaced the plugs/plug wires 02 sensors and did an injector balance and everything came out OK. Please offer any feedback / advice that you have. Thanks
    Sep 2009
    Upper California
    Artic
    2002 Z28
    don't everyone chime in at once
    Member 2000dreambird's Avatar
    Jun 2009
    Mass
    silver/black
    00 trans am,SLP,Ws6
    could be anything really, i had a grand Prix that was misfiring because the boot on the spark plug wire had traveled up the wire a little ways, this caused the plug to arc out on the block instead of firring in the cylinder
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    i have to get inside my motor, i have a vibration issue that might pass for a missfire.
    we'll see pretty soon. i have this weekend off.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You would hear a bent push rod. It would sound like a constant ticking. Why do you think you have a bent push rod? Did you over-rev the motor?
    Misfire is usually: bad wire, bad plug, wire not fully seated on the plug, or a vacuum leak. In your case, since you changed the wires and plugs already, I would guess a vacuum leak.
    Have you checked your fuel pressure? If should read 58psi. If it isn't, you aren't getting enough fuel which could be a fuel pump issue, fuel filter, or a bad injector.
    Pittsburgh
    2008 Hummer H3
    A weak coil or coil ground can cause intermittent misfire also..
    Sep 2009
    Upper California
    Artic
    2002 Z28
    Quote Originally Posted by jsmith564` View Post
    Good luck with that. hope its not too bad for you.
    fuel pressure is good, just replaced the filter, did an injector balance and they all perform well
    haven't over revd the motor, assumed it was a bent pushrod because I fixed everything else it could have been lol. not sure on the vacuum leak. Don't know how to find one if I did
    looking into it
    May 2011
    Socal
    2002 Corvette
    Could be a broken rocker arm. Especially if its broken on the intake side, itll just feel like a miss and vibration when you rev it.
    Houston, Texas
    2000 C5 Torch Red
    Just because it was recently replaced doesn't make it free and clear from being the culprit.
    Id start with the most recently changed things. Check and make sure one of your wires didn't wiggle loose. Had a buddy with a bad mis. Wore a thick glove to protect from heat and put pressure on the wire boot at the coil and then the plug. One was pulsing differently from the rest. Pulled, checked and replaced it to fix the issue.
    Guessing your not throwing any codes yet.
    if you haven't bounced off the limiter I doubt it's a pushrod.
    Member Jay37's Avatar
    Nov 2010
    St Marys GA
    '05 GTO
    I'll tell you how I check for vacuum leaks, I understand stand "it's not safe" so do it at your own risk, I only say that so this thread doesn't get filled up with people concerned about my safety. Although I have never had a problem.
    Just put gas in a spray bottle, and spray all your air hoses with the car running, and if your rpms change that is a vacuum leak.
    RUDE, CRUDE, AND SOCIABLY UNACCEPTABLE.
    I've used brake cleaner.
    Junior Member Keith01's Avatar
    May 2011
    2001 Camaro
    WD40 works also.
    Member ldurham's Avatar
    Jul 2010
    Wise County
    I wouldn't use Brake clean or WD-40.Get a bottle of carb/throtttle body cleaner and spray it all around your hoses and intake manifold. If you have a vacuum leak it will suck in the cleaner where ever the leak is and you will hear a change in your RPM's.
    Member km346's Avatar
    Nov 2008
    masssaaechuuuseettes
    1998 hardtop SS
    Quote Originally Posted by ldurham View Post
    THIS... carb cleaner isn't corrosive to paint/rubber like brake cleaner, or as dangerous as spraying gasoline.
    Nov 2010
    St Marys GA
    '05 GTO
    can this thread die yet?
  1. Tick noise when warm after bent pushrod change
    By dave04da in forum Internal Engine
    Last Post: 07-01-2014, 09:00 PM
  2. Help: Bent Pushrod
    By cowstandmoto in forum Firebird / WS6
    Last Post: 06-06-2013, 03:49 PM
  3. bent pushrod issue
    By natews6 in forum Internal Engine
    Last Post: 06-15-2010, 09:09 PM
  4. Help: I think i have a bent pushrod!
    By camaroluvr447 in forum General Help
    Last Post: 12-24-2009, 10:18 AM
  5. Bent Pushrod, head damage, need opinions pls
    By Pushead in forum Internal Engine
    Last Post: 08-24-2008, 07:53 AM
