Results 1 to 19 of 19
Thread: Speedometer stop working
04-09-2011, 12:05 PM #1
Anyone know where it is? Is there a fuse? Thanks in advance.
Sent from my Nexus One using Tapatalk
04-09-2011, 06:00 PM #2Senior Member
- Apr 2008
- Madison, WI
no fuse specifically for the speedo. You might have a problem with the vehicle speed sensor or its wiring. Any recent work done that might have affected that stuff??
04-10-2011, 06:08 AM #3
04-10-2011, 01:38 PM #4Senior Member
- Apr 2008
- Madison, WI
The vehicle speed is located in the tailshaft housing on the transmission.
04-10-2011, 07:47 PM #5
check if the sensor got disconnected from the tranny...i disconnected it once from a camaro i had once and forgot to connect it and the speedometer would work till i connected it back
04-10-2011, 07:51 PM #6
Most likely a wheel speed sensor from the driver's side rear. Same deal happened to my BMW a couple months ago. Does the speedometer just not work completely or does it randomly do that at times?
04-11-2011, 07:42 AM #7
04-11-2011, 08:46 AM #8
04-11-2011, 08:49 AM #9
04-11-2011, 12:07 PM #10Junior Member
- Jul 2008
- Felch Mi
Check the sensors.
04-11-2011, 02:14 PM #11
Except F-bodies do not have speed sensors in the wheels, and the ABS sensors that are there have nothing to do with the speedo..
OP....
Do as Cutlass suggests and check the actual speed sensor in the tail shaft housing of your trany.. good luck
04-11-2011, 02:18 PM #12
04-11-2011, 04:12 PM #13
04-11-2011, 04:45 PM #14Member
- Northern Virginia
BLACK- 2000 Camaro SS
04-11-2011, 04:55 PM #15Member
- Northern Virginia
04-11-2011, 04:57 PM #16
No, they are hall sensors they detect lockup through gaps in the reluctor rings....
04-11-2011, 04:57 PM #17
There is a wheel speed sensor mounted to the backside of the backing place that reads the rotation of the reluctor ring that is pressed onto the end of the axle. This signal is then fed to the computer. At least this is how it works on 4 channel vehicles.
3 channel rear ends the sensor is on the pumpkin.
This has nothing to do with the speedometer though, as mentioned.
04-11-2011, 04:58 PM #18
04-11-2011, 05:19 PM #19
Speedometer not working
By Promise517 in forum Stereo and ElectronicsReplies: 2Last Post: 04-11-2011, 03:46 PM -
Help: Speedometer needle stopped working?
By onetroubledguy in forum Firebird / WS6Replies: 9Last Post: 01-10-2009, 02:51 PM -
Speedometer intermittently stops working
By gamitchSS in forum Camaro / SSReplies: 7Last Post: 05-16-2007, 07:50 AM -
speedometer not working after head unit install???
By MHarvey in forum Stereo and ElectronicsReplies: 2Last Post: 03-03-2006, 06:55 PM
