Results 1 to 20 of 23
    Junior Member Jager686's Avatar
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Exclamation Constant hesitation after load, need assistance!!
    Hello Everyone,
    I've been getting a bit frustrated with my 94 Firebird 3.4. It sounds like "putputputput" lol COUGH, A "putter machine" after I put it in drive and take off, usually after 2k rpms and stays that way till I restart the engine. I've installed new plug n wires and a cam sensor hoping that would help but nope! Keep in mind the car runs fine till I put a certain amount of load on it... I've taken to 2 shops in town and they couldn't find the problem. Plus the security light does stay on constantly however the engine light doesn't come on. ANY IDEAS?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Have you replaced the fuel filter?
    The opti could also be the culprit.
    Orlando, FL
    Mean Black
    Quote Originally Posted by Jager686 View Post
    Hello Everyone,
    have you scan for codes? I know that you don't have a light but it might have some codes stored in the memory. Some codes don't throw a light. Does it idle okay?
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    No I havnt replaced the fuel filter yet, but y do u think its the filter causing the problems? Ha, was just thinking of the opti too... is there any way to test it?
    Orlando, FL
    Mean Black
    if the filter is clogged it will create fuel pressure issues. You can check the fuel pressure with a fuel pressure gauge at the fuel rail. there is a port there. the fuel pressure needs to be 58-60 psi. If you haven't replace the filter in a while is a good idea to so. The way gas is these days they get clogged easy. i change mine every 7k -10k miles.
    Not sure on how to test the opt. im sure some more will chime in.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    No I havnt scan for codes yet, will stop at advance auto tmw to do that for my next step for my needle in the hay stack. The idle on the other hand when I first start it seems it wants to die... I do have a smart phone so I could take a video of the idle if u like??
    Orlando, FL
    Mean Black
    have you clean your TB and MAF?
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Yes, was the first thing I did before I started to replace parts ntm the mechanics did it too, but they also said the car was running rich..
    99 WS.6 - Modified
    Running rich would suggest a problem more towards the opti - no spark to burn the fuel. Not saying it is the problem, but I would look in that direction.
    Orlando, FL
    Mean Black
    I will start by scanning for codes and post them tomorrow if you had any.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Will do
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Err wait a sec I have coil pack on my v6 so no on the opti spark
    rsg98Z28 rsg98Z28's Avatar
    Atlanta, GA
    1998 Camaro Z28 vert
    make sure its not the MAF, if it idles bad u can usually hit it a few times with like a screw driver handle, if it getts better uve found ur culprit, also it could be a vacuum leak potentially.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Ok so no codes came up on the scan tool, however the guy said he couldn't check the egr stats or anything else so he assumed the computer is bad
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Hmm so update, I flushed out the heater core for the first time this year to get the heater to work. All that came out was brown goop, odd huh.. but afterwards here's the kicker, before the car fumbled about 2k load or 20 mph n now its fumbling around 35-40mph and or 4k load... I wonder if I flush the whole system it would clear the beast of this illness
    NO BALLS -> NO LIFE
    1994 V6 Salvage FIREBIRD
    Full 98-02 T/A Body and T-Top Conversion Completed..
    West Coast Creations Hood
    American Racing Thrust Rims 16"
    Engine swap next year debating wat engine
    Build your own car like a man, dont be a pussy and buy one!
    Central Florida
    2000 Z28
    I had a similar problem in my 95 3.4. It ended up being the coil pack mounting plate getting warped over time allowing moisture and dirt between the coil packs and ignition module beneath it. After cleaning the gunk out, I cutout 1 or 2mm thick rubber sheets to match the bottom of the coil packs, cut slits for the ignition module prongs and sandwiched the rubber gasket cutout between the coil packs and module. Problem solved. Try it for a couple of bucks in rubber sheets.
    Sent from my DROID2 using Tapatalk
    Orlando, FL
    Mean Black
    I recommend that you do a whole system flush but i don't think is related to your issue. Have you check for vaccum leaks?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Brown goop is from your coolant going bad, and since the heater core has some pretty tight places, it typically suffers the worst.
    I'd get the whole system flushed, but I don't think that could be causing your issue.
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    Quote Originally Posted by tremiles View Post
    Ok ill giv it a a shot, but I've already cleaned the prongs
    Jul 2009
    Redwood Falls, MN
    HOT RED!!
    1994 Firebird
    I've replaced the vacuum hoses by the tb 3 years due to a vacuum leak, they've been holding so far from what I can hear...
  1. 1800-2000rpm constant idle
    By cammedta in forum General Help
    Last Post: 12-10-2013, 09:25 PM
  2. Help: Assistance please
    By Jvarela in forum General Help
    Last Post: 02-29-2012, 12:08 PM
  3. 01 z28 six speed Big Hesitation u/Load
    By 5abivt in forum General Help
    Last Post: 09-01-2009, 12:29 AM
  4. Constant "Database Errors"
    By AKIRA in forum Almost Anything Goes
    Last Post: 02-02-2007, 03:22 PM
  5. i need some serious assistance
    By RyanoLS1on in forum Wheels and Tires
    Last Post: 09-16-2006, 01:32 AM
