    Curwensville,PA
    black/pewter
    1999 Z28
    More tire Questions!!
    Need a bit of help on buying tires. I have 17x9 rims with 245/45/17's on now. Would like to go a bit wider (275/40/17), but was wondering if I could have two different sizes on front/back. Would that look good and does it cause any problems for the car? Or should i jsut keep with the same sizes front and back?
    Thanks for the help.
    Member 99WS6MAN's Avatar
    TX
    99 Pontiac WS.6 Trans Am
    Quote Originally Posted by z28fireman
    Well I have 275's all around ... I started with 275 on the back and 245 up front but after time didnt like the way it looked. I like the look of big/ wide tires all the way around, guess it just what you like! Dont have any problems turn the wheels ......
    99 WS6 Trans AM
    Hurst Shifter
    Aftermarket Throttle Body
    KN Air Filter
    Strut Tower Brace
    Z06 Rims
    Ohio
    2002 WS6 Trans Am
    The only problem you will run into is rotating the tires for even where. Most of the better performance tires are directional so you cant just rotate side to side it has to be front to back.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    shouldn't have any problem... unless the backspacing on your rims are out of whack.
    275/40-17 are meant to be installed on wheels of 17x9 to 17x11
    So there is no issue there.
    Eugenio_SS
  1. '02 WS6 wheel/tire questions (N90 & Honeycomb)
    By Whamhammer in forum Wheels and Tires
    Last Post: 07-26-2014, 02:05 PM
  2. Tire questions
    By dethinboots in forum GTO
    Last Post: 01-08-2013, 04:17 AM
  3. tire size questions to the tire gurus!
    By vonskeezy28 in forum Wheels and Tires
    Last Post: 04-30-2011, 09:01 AM
  4. tire and rim questions (help)
    By knightryda01 in forum Wheels and Tires
    Last Post: 01-19-2009, 11:49 AM
  5. Tire questions
    By Fire Chicken of Doom in forum Wheels and Tires
    Last Post: 10-09-2006, 10:29 PM
