    Senior Member Getzen_Guy's Avatar
    Oklahoma
    2000 T/A
    Magnacharger on a 2000 TA
    So, I can get a magnacharger off of an lq9 incredibly cheap.
    Now I know a magnacharger setup requires cutting the cowl, and changing over the drives.
    I'm not even sure if this particular sc will fit an fbody
    Has anyone done this before, if so I would really appreciate some input
    Thanks in advance!!
    Member parnelligq's Avatar
    Elkhorn, Wi
    black99, silverY2K
    1999 z28 & Y2K z28
    I havent seen it done but... I think before I resort to cutting the cowl, I would look into adding spacers between the k-member and the frame. Unbolt the K-member and lower the motor. Install the blower just the blower and manifold. Then raise the k-member up till it is about .25 inch of touching the cowl. Measure the distance between the K-member and the frame. This is the size spacer you will need. You will also need longer bolts. Use nothing less than a grade 5 bolt and preferably a grade 8. I know its a lot of work to see if this will fit but its better than cutting the cowl. Let me know if you cant find specific spacers and I will whip them up.
    Wisconsin
    2001 Camaro SS M6
    Not sure if it will work but before I would do the spacer idea, I would just buy an aftermarket K-member. They usually have a 1.25 inch drop compared to the stock
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Oklahoma
    2000 T/A
    Bolting to an ls1 or ls6 won't be an issue correct? I'm replacing my current engine with a crate longblock, so I was going to buy this supercharger and run 5-7psi on stock internals as to not void my warranty
  1. LS2 and TVS2300 MAGNACHARGER
    By CAMAROmj454 in forum Forced Induction
    Last Post: 09-14-2011, 06:47 AM
  2. LS1 Magnacharger?
    By KnightmareWS6 in forum Forced Induction
    Last Post: 01-26-2011, 09:57 AM
  3. Thoughts on the Magnacharger
    By 03hemitime in forum Forced Induction
    Last Post: 10-21-2010, 07:48 PM
  4. Wtb-magnacharger for ls1
    By fastfirebird2002 in forum Parts Wanted / Trade
    Last Post: 04-24-2009, 05:44 PM
  5. Here is a new pic of magnacharger
    By superchargedblackgto in forum GTO
    Last Post: 03-02-2007, 12:26 PM
