Results 1 to 10 of 10
Thread: SLP lid
04-01-2011, 10:05 PM #1
- Apr 2011
- Florida
Black- Trans Am WS6 2000
SLP lid
I installed a SLP lid on my Trans Am WS6 2000. I have problems starting my car. Any ideas to solve the problem?
Thank you
04-01-2011, 10:57 PM #2
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Welcome to the site.
I install it on my ss. I didn't have no problems. Did u plug all the sensors? Double check that. Because I dnt think the problem has to do something wot the lid
04-02-2011, 04:25 AM #3
04-02-2011, 05:49 AM #4
do you have a SES light on? The other thing I could think off is that there is a hole somewhere in the hose. You did put the MAF the right way correct?
04-02-2011, 07:30 AM #5
My money says he Didn't hook up the maf sensor
04-02-2011, 07:44 AM #6
- Jul 2009
- North of the Motorcity
Wouldn't it still run if the MAF was unplugged? Not drivable but still idle?
04-02-2011, 07:49 AM #7
- Oct 2006
- St. Clair Shores. Michigan
It will still run without the MAF plugged in (ask me how I know).
Did you disconnect the battery for install ? double check the terminal connections.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
04-02-2011, 11:19 AM #8
- Apr 2011
- Florida
Thank you for your help. When I installed the lid I also installed the racetronix fuel pump, that also gave me some problems. The mechanic who did it told me it was the pump. told me to put back the stock. I didn't. The car runs great. We plug the MAF and all sensors, I made sure of that. I took it back to my regular mechanic, who is by the way against mods, and told me to change the air sensor. it was broken.. He did changed. He said the computer gives an error, the air mix in the catalytic converter. It starts better but not great. He told me to put back the stock lid. Do I need a tune for that? I am installing a ported and polished throttle body and a SLP loudmouth 2 exhaust soon, Do I need a tune?
Thank you again
Klaus
04-02-2011, 02:21 PM #9
The lid shouldn't cause any issues. No tune for the lid. You have another issue. You mention that the air intake sensor was bad. If you disconnected the battery the PCM needs to relearn the idle which it takes a few miles. Do you have a service engine soon light on?
04-04-2011, 08:04 AM #10
Sounds like you fixed it by replacing the air sensor. Jay is right it will take a couple of starts for the PCM to re-learn.
If that "mechanic" is against a simple and proven air lid upgrade I'd find another "mechanic". No tuning necessary for a lid or P&P TB. I've only had to get a tune after I did my LT headers and I've mod way more then you. That was to get rid of the rear O2 sensors and adjust the fueling tables.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
