Results 1 to 2 of 2
    jadams4338
    Guest
    Max RPM with TEA Stage 2 Heads
    I have a 95 Trans Am that I put some stage 2 heads on with a
    2.000 Severe Duty Intake Valve
    1.560 Severe Duty Exhaust Valve
    1.440 Dual Springs 150 lbs@ 1.800” and 380 lbs@ 1.200”
    1.440” Chromoly Retainer
    11/32” 7 Degree Machined Locks
    1.550 Inner Diameter Spring Locator
    .341x.563 Viton Seals
    It also has a custom grind 230-236 duration cam, with COMP CAMS R Lifters. I was wondering what is the max rpm that I should bring it up to. I currently have the rev limiter set to 6300 rpm. Anyone else running theirs up this high, or an I nutz?
    Oct 2001
    Colorado
    95 Z28
    I assume you have good pushrods and roller rockers as well... I dont think you'll make much power beyond 6500 rpm, but 6300 should be fine. The stock bottom end will be ok for that, but nonetheless it will give up at some point.
  1. Prc stage 1 ls6 heads v2 cam?
    By Z28SMG in forum Internal Engine
    Last Post: 08-17-2011, 11:56 AM
  2. Patriot Ls6 Stage 2 vs TSP 5.3 stage 2.5 Heads
    By jetaws6 in forum Internal Engine
    Last Post: 11-16-2010, 06:11 AM
  3. PRC 5.3l Stage 1.5 Heads VS. PRC LS6's
    By sfletch2000 in forum Internal Engine
    Last Post: 09-10-2007, 11:32 PM
  4. F/S: 231/237 TSP cam & Stage 2 LS6 heads
    By Y2KPewterSS in forum Parts For Sale / Trade
    Last Post: 04-22-2007, 11:42 PM
  5. Stage 1 ls1 heads FS
    By Blksilvr in forum Parts For Sale / Trade
    Last Post: 09-20-2005, 06:36 PM
