Results 1 to 20 of 25
    Member cancam99ss's Avatar
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    i really need help. camaro is pissing me off
    So about two months ago my car was running perfectly fine then it starts to blow smoke, but the temp gauge doesn't show that it is over heating. it was boiling the coolant out of the reservoir tank and the reservoir tank only i have since then checked the relays, fuses, changed the thermostat, replaced the coolant temperature sensor, and now i am out of ideas. MY cars fans are not going on unless the a/c is on. today i finally replaced the coolant temperature sensor and realized that the fans are still not coming on... after 20 in the car and driving it the temperature started to go up (for the First time ever) and then was once again throwing the coolant out through the reservoir tank.
    i was told to check the oil to see if it had water or was milky, which could mean a head gasket, but everything seemed fine... i can take anything..... please help im desperate at this point...
    East of Cleveland, Ohio
    99 WS.6 - Modified
    What year is your car?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Just throwing some random ideas out there....
    Check your radiator cap (it may not be holding pressure).
    Check the relays again.
    The new temp sensor you just installed could have been a faulty part.
    You could possibly have air in the system too.
    The fact that your fans come on when you turn the AC on is evidence that the fan motor is still good.
    Is your water pump in good, working order?
    Member parnelligq's Avatar
    Elkhorn, Wi
    black99, silverY2K
    1999 z28 & Y2K z28
    If the fan comes on with the AC then the coolant temp sensor is bad. The computer is not getting the temp reading because the sensor is not sending the reading.
    Elkhorn, Wi
    black99, silverY2K
    1999 z28 & Y2K z28
    Also did you use a standard thermostat or a 160?
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    I had same issue a little while back and it ended up being the water pump. Changed everything that was mentioned and the last thing that made it start working was the water pump
    Elkhorn, Wi
    black99, silverY2K
    1999 z28 & Y2K z28
    Yea, come to think of it I also replaced the water pump.
    old timer blue02Z's Avatar
    2002 Z28
    Quote Originally Posted by parnelligq View Post
    Not necessarily, could b the ect sensor or harness or the pcm. Like stated above also prolly replace ur radiator cap. U need to look at a data display on a scan tool and c if the pcm is getting the temp signal. Also have u checked for any codes?
    Member robs98mysticZ's Avatar
    Mar 2011
    Waynesboro, Pa
    Mystic Teal Metallic:320c
    1998 Camaro Z/28
    mine does that on occasion i think its the tstat
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    If the rad cap wasn't holding pressure shouldn't it be leaking thru the rad cap too?? Also I installed a 160 stat...
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    I have a 99 Camaro ss m6
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    whats that sensor on the front driverside head by the exhaust manifold and spark plug #1?
    i left that unpluged doing some work on the car when i changed the plugs and the fans came on and car ran like shit.. not saying it might help or not.. but i was wondering what it is for.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Temp sensor.
    With the radiator cap off, do a compression test and , put air to each cylinder, to see if any of them make the radiator bubble. If so, head gasket.
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    Quote Originally Posted by bills98ta View Post
    Temp sensor.
    Heard of the compression test, what do I actually have to do to perform this
    Feb 2007
    St Thomas, PA
    Buy a compression tester with a quick disconnect, that will allow you to hook up an air hose to it.
    Remove all spark plugs and screw it in the plug hole, crank the engine over, then read the gauge. They should all be close on the readings.
    http://www.autozone.com/autozone/acc...er=347021_0_0_
    Quote Originally Posted by cancam99ss View Post
    if i'm not mistaken the fans will need to be tuned to the new stat... the t-stat is kicking in and the fans are still waiting on the stock stat temps to go on...
    This is correct.
    Sep 2008
    99 SS
    I think everyone cover most of the probable causes. Do you still have the Power Steering coolant?? If you do I would take it out while you are there, it cost me two PS pumps because it broke and it created a mess. I had PS fluid on my coolant and coolant on my PS fluid. It cost me a water pump, t-stat, 2 PS pumps, and a rack and pinion. Just a head up since you are going to be working on it.
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    Just took the ss to the shop will hopefully have a response as to what is going on today .... Keep you posted
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    Well he got backed up tried everything I did tomorrow I am getting new ls1 fans installed.... Will keep you posted
  1. Wife is pissing me off.
    By Spikito in forum Almost Anything Goes
    Last Post: 04-04-2012, 05:45 AM
  2. My car is pissing on itself
    By SMWS6TA in forum General Help
    Last Post: 03-01-2012, 05:22 PM
  3. Cars pissing me off
    By Spikito in forum Camaro / SS
    Last Post: 03-23-2011, 11:49 AM
  4. He's pissing everyone off
    By GTP231 in forum Political / Debate Forum
    Last Post: 03-10-2010, 07:01 PM
  5. Civic pissing me off
    By GottaHaveLS1 in forum Kill Stories
    Last Post: 07-09-2006, 08:34 AM
