Thread: Electric seat
    2000 TA WS6
    Electric seat
    Hey Guys
    I have 2000 WS6. My driver power seat has stop working. The seat will not move and the lumbar is also not working. I have checked the fuse and it is fine. My rear defrost works which confirms the fuse is good . I have also checked the electrical connections under the seat. They were plugged in, so I unplugged them and then reconnected them. At this point I am at a loss of what to do or what too check.
    Do you have a DVOM or test light? If so, I would probe the connections for power. That will help to isolate the problem.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    If you are getting power to the seats, can you hear the motor(s) trying to work?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    If the power is good, check the ground. Its the black wire coming off the seat switch. The ground location as described in the service manual is:
    "Bolted to the left rocker panel at the floor pan bar"
    2000 TA WS6
    I have checked the ground and it is fine. The motors are not running. I also checked the passenger seat and it's Lumber support is also not working. So most likely the seats are not getting power. I have checked the connections under the seat and they are connected. Does anyone know which wires run the power to the seat movement and Lumber control.
    Madison, WI
    2001 Silverado Z71
    Its the orange wire
    2000 TA WS6
    Thanks Cutlass!
    I found the orange and black connector that brought the main power into the seats. The connection itself appeared fine, but I unplugged it and and plugged it back in. I then noticed a little corrosion around the seat side of the orange wire. I decided to construct a jumper wire and when moving the connector around the seat side orange wire seperated from the connector, due to the corrosion and was not connected inside.
    So I now have the jumper wire installed and the seats and lumber work fine.
    Thanks again for all the help you guys provided.
    Glad to hear it was an easy fix.
    Madison, WI
    2001 Silverado Z71
    Quote Originally Posted by 2000WS6 View Post
    Thanks Cutlass!
    Glad I could help. Enjoy those seats!
  1. Electric Seat knob..
    By z28_81 in forum Appearance Section
    Last Post: 10-31-2012, 01:34 PM
  2. Help: Stock Tan 93-02 Trans Am Seat or Seat Cover (Leather)
    By fbodyNATION in forum Firebird / WS6
    Last Post: 09-20-2011, 11:15 PM
  3. Wanted: Stock 93-02 t/a tan driver side leather seat,or seat cover
    By fbodyNATION in forum Parts Wanted / Trade
    Last Post: 09-20-2011, 12:29 AM
  4. 02 camaro driver seat electric question
    By blackhawk01 in forum Stereo and Electronics
    Last Post: 01-14-2008, 07:48 PM
  5. Electric front seat heater
    By snobrd in forum General Help
    Last Post: 02-08-2007, 10:55 AM
