Results 1 to 20 of 20
Thread: drivetrain
03-24-2011, 06:06 PM #1
drivetrain
Hello people im new to this site just want to say hi.i have some questions about drive
train vibration 95 camaro z28
03-24-2011, 07:08 PM #2
Welcome! Could be several things -- an out of balance wheel, a u-joint on its way out, a bent rim, bad transmission mount, etc... When does it do it?
03-24-2011, 07:16 PM #3
Welcome to LS1.com. You might want to ask the same quetions in this section. http://www.ls1.com/forums/forumdisplay.php?f=8 You should get a lot of replies there...
03-24-2011, 07:21 PM #4
Starts to vibrate at sixty and gets worst as you go, but it's not constant had drive shaft rebalanced reset pinion angle butit still has the balancer on the drive shaft
03-24-2011, 07:29 PM #5
Welcome to the site
As Thunder mentioned, post up your issue in the tech section. More people will reply in there.
03-24-2011, 07:35 PM #6
Thanks I will do that.
03-25-2011, 06:41 AM #7
Welcome Ron
03-25-2011, 07:40 AM #8
Thanks buddy appreciate the welcome
03-25-2011, 08:07 AM #9
If you match your 60 mph rpm in a lower gear, do you get a vibration? If not, it is likely a tire balance issue. Some of our cars would only shake over a certain speed when it was an out of balance wheel.
03-25-2011, 08:14 AM #10
Yes even if it is in a lower gear it still vibrates
03-25-2011, 08:34 AM #11
03-25-2011, 08:45 AM #12
Same speed rpm does not make a difference
03-25-2011, 09:58 AM #13
- Nov 1999
- over here...
could be motor mounts... have you ever replaced the bushings on sway bars and other suspension parts???
03-25-2011, 10:08 AM #14
Yes I have new control arms new panhard bar torque arm kyb ajustables new springs trans and engine mounts
03-27-2011, 08:00 AM #15
03-27-2011, 08:01 AM #16
Thanks man appreciate the welcome
03-27-2011, 09:26 AM #17
- Jul 2009
- North of the Motorcity
Welcome!
If your problem gets worse as speed increases, I think it might be a rotating problem. Similar to the ones Jeff mentioned.
03-27-2011, 10:16 AM #18
I think I got it figured out their is a balancer on the propeller shaft that's wobbling I
I ordered a new drive shaft we will see what happens
03-27-2011, 06:14 PM #19
03-27-2011, 06:21 PM #20
the funny thing is it has been balanced twice I figured they would check that
Question: IV Gen drivetrain in III Gen truck
By Z28dryva in forum LSx Retrofit and SwapReplies: 9Last Post: 02-11-2013, 06:55 PM -
drivetrain protection...
By blackhawk01 in forum DrivetrainReplies: 0Last Post: 02-29-2008, 04:23 PM -
WTB/ LS1 drivetrain
By MonkiMajyk in forum Parts Wanted / TradeReplies: 2Last Post: 10-13-2006, 11:46 AM -
drivetrain
By bmwmike in forum Parts For Sale / TradeReplies: 1Last Post: 04-10-2006, 01:46 AM -
A4 drivetrain
By pewterz28 in forum Automatic TransmissionReplies: 1Last Post: 01-26-2006, 09:51 AM
