03-23-2011, 06:18 PM #1
found a simple cheap way to fill the transmission for VETTES
[ame]http://www.amazon.com/Sprayco-Long-Reach-Plant-Waterer/dp/B000VYGCZW[/ame]
works on an A4
I'm thinking it should work on a manual
I just used a heat gun to make the tube bend the way I needed it so it would fit.
I doubt it would work with 90wt but dexron flows easily and it worked to perfection
found one at a local hardware store for 4 bucks
FYI : the tube goes to the bottom so you just squeeze it to make it work
03-27-2011, 09:37 AM #2
- Apr 2006
- phila
I use a pump that screws into the top of a quart oil bottle. Got it a Sears for $4. Looks something like this:
http://automotive.hardwarestore.com/...mp-126773.aspx
03-28-2011, 09:58 PM #3
have one and like this better
it's easier to use
03-29-2011, 03:40 AM #4
I have a Plews suction gun that I can use to push fluids into hard to reach fill holes. Like your setup, it will work at any angle. Nice find.
03-29-2011, 07:17 AM #5
I have a suction pump too
This was easier
Found a TH350 cheap and
By 95camaroZNC in forum Automatic TransmissionReplies: 6Last Post: 06-22-2010, 04:43 AM -
transmission code found info
By acollins2187 in forum Automatic TransmissionReplies: 2Last Post: 08-21-2007, 11:52 AM -
Found a good transmission shop...
By Soul TKR in forum Western MembersReplies: 6Last Post: 05-22-2007, 01:41 PM -
Found a tuner, cheap too
By 98-LS1 in forum Internal EngineReplies: 3Last Post: 11-16-2006, 04:00 AM -
found an ls1 cheap
By boobs in forum Camaro / SSReplies: 3Last Post: 07-20-2006, 08:33 AM
