Results 1 to 20 of 53
Thread: Racetronix pump install in pics
03-20-2011, 08:38 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
I have had a racetronix pump and hotwire kit sitting around for a yr......just had spring break so there was no excuse.......my car just turned 160k so I knew my pump was on borrowed time....I had a 89 IROC that the pump went out at 100k and left me stranded....cant afford that on my DD......dont have as many pics as I would like......my battery in the camera died right when I started the pump assembly.......but the instructions from racetronix are the best I have ever seen for putting a aftermarket part in......you are on your own for getting the tank out.......or cutting a trap door.......but I dropped the tank.....the instructions for the hotwire kit install are kinda....sparse.....only a piece of paper telling you where the connections go....which is only 2 connections......fuel pump and the batt side of the alternator......how to get between the 2 is up in the air.......so I went a direct route for the hotwire kit
follow alongLast edited by sjsingle1; 03-21-2011 at 09:59 PM.
03-20-2011, 08:38 PM #2Senior Member
- Jan 2010
- texas
disconnect neg terminalLast edited by sjsingle1; 03-20-2011 at 08:55 PM.
03-20-2011, 08:38 PM #3Senior Member
- Jan 2010
- texas
remove the ring around gas tank inletLast edited by sjsingle1; 03-20-2011 at 08:55 PM.
03-20-2011, 08:39 PM #4Senior Member
- Jan 2010
- texas
remove plastic panel covering the filler tubeLast edited by sjsingle1; 03-20-2011 at 08:56 PM.
03-20-2011, 08:39 PM #5Senior Member
- Jan 2010
- texas
10mm bolt holding the filler tubeLast edited by sjsingle1; 03-20-2011 at 08:56 PM.
03-20-2011, 08:39 PM #6Senior Member
- Jan 2010
- texas
never noticed the tank had handles....next step is remove tank.....but the exhaust is in the way......I bought the car with a borla.....and they welded all the sections of pipe together....so the whole thing had to come out.......damm near had to take the rear end out to get the exhaust out.....took me 2 days
.......after exhaust is out of the way......remove all the heat shields....be careful....those edges are sharp
03-20-2011, 08:40 PM #7Senior Member
- Jan 2010
- texas
2 .....15mm bolts hold the tank inLast edited by sjsingle1; 03-20-2011 at 09:01 PM.
03-20-2011, 08:40 PM #8Senior Member
- Jan 2010
- texas
03-20-2011, 08:41 PM #9Senior Member
- Jan 2010
- texas
disconnect these 2 fuel lines and the main line to the fuel filter.....and then disconnect the wire harnessLast edited by sjsingle1; 03-20-2011 at 09:02 PM.
03-20-2011, 08:41 PM #10Senior Member
- Jan 2010
- texas
look ma.....no tankLast edited by sjsingle1; 03-20-2011 at 09:03 PM.
03-20-2011, 08:42 PM #11Senior Member
- Jan 2010
- texas
trust me......it does not come out this clean......cleaned it so no crap would get in there when I pulled the pumpLast edited by sjsingle1; 03-20-2011 at 09:04 PM.
03-20-2011, 08:42 PM #12Senior Member
- Jan 2010
- texas
you have to twist that star looking thing to get the pump out.....not as easy as it looksLast edited by sjsingle1; 03-20-2011 at 09:05 PM.
03-20-2011, 08:43 PM #13Senior Member
- Jan 2010
- texas
pump out....woo hoooLast edited by sjsingle1; 03-20-2011 at 09:05 PM.
03-20-2011, 08:43 PM #14Senior Member
- Jan 2010
- texas
I expected the tank to be full of crap....but it was pretty clean......thanks TECHRONLast edited by sjsingle1; 03-20-2011 at 09:06 PM.
03-20-2011, 08:44 PM #15Senior Member
- Jan 2010
- texas
there are 2 fuel sock filters on the pump.....1 on the fuel bucket......and 1 on the pump itself.......the racetronix kit came with the pump filter......you are on your own for the bucket sock....quick trip to the dealer got me 1 ASAP......do not have a pic of it.......but the old bucket sock was COAL BLACK.....talk about nastyLast edited by sjsingle1; 03-21-2011 at 08:20 AM.
03-20-2011, 08:44 PM #16Senior Member
- Jan 2010
- texas
you can see some of the red of the new pump down in thereLast edited by sjsingle1; 03-21-2011 at 08:21 AM.
03-20-2011, 08:45 PM #17Senior Member
- Jan 2010
- texas
03-20-2011, 08:46 PM #18Senior Member
- Jan 2010
- texas
03-20-2011, 08:46 PM #19Senior Member
- Jan 2010
- texas
you can see the 2 arms of the sender and the 3 fingers on the arms......they contact to send signals to the fuel gauge.....there was so much slop in the plastic assembly that the fingers did not make contact all the time.....no wonder my fuel gauge was so wonky.....that dark thing in the middle is actually a brass fitting that couples the 2 pieces together.....I knocked it out and bent the fingers so that they made contact despite all the slop in the assembly......and I made sure when I reassembled it that the brass fitting was good and tight in there.......so far so good on a gas gauge reading
03-20-2011, 08:46 PM #20Senior Member
- Jan 2010
- texas
new sock.....this inlet feeds the bucket fill tubeLast edited by sjsingle1; 03-20-2011 at 09:18 PM.
Help: New racetronix pump not pumping
By ponyslayer in forum General HelpReplies: 14Last Post: 11-27-2011, 05:21 AM -
Racetronix pump whinning
By JayTA98 in forum General HelpReplies: 6Last Post: 07-24-2010, 03:29 PM -
Racetronix pump priming?
By JayTA98 in forum General HelpReplies: 25Last Post: 04-27-2010, 01:54 PM -
Racetronix Fuel Pump and Hotwire Install Instructi
By WS6ICK in forum General HelpReplies: 17Last Post: 09-13-2008, 10:36 AM -
98 LS1 Racetronix fuel pump
By underated98z in forum Parts For Sale / TradeReplies: 0Last Post: 04-12-2007, 11:51 AM
