Thread: p1133
    Nov 2010
    ft worth tx
    maroon
    2001 z28
    p1133
    my 01 z28 is giving me this code is it the front o2 sensor? i just had catback exhaust put on they found my drivers side cat was leaking so the sealed it up for me its a 01 z28 by the way.....ive read that some of the gaskets can give off fumes that will trip that ?
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    I assume since since you said cats you dont have lt headers? Sometime certain sealants they use can damage o2 sensors but since idk what sealant they used its hard to say. Now a p1133 code means the sensor is slow to respond to the pcm with reading from the exhaust in a stock car this normally means the o2 is at the end of its life and is getting lazy so its probably time to swap a new one in.
    Quote Originally Posted by txmz28 View Post
    it's not the gaskets but sealants... the only way (from what i've read) is if thoes sealants burn and release the chemicals that kill the 02 sensor... if you've installed headers moving the 02 bung further tword the collector could help... try getting the car tuned and see if that fixes it...
    Nov 2010
    ft worth tx
    maroon
    2001 z28
    thanx ill look into getting a new o2 sensor i have an idea that once they sealed the cat up something with it being a sealed system caused by the change in the exhaust...heres what my code reader pulled off bank one control shifted lein...
  1. P1133 help
    By Mikat1 in forum External Engine
    Last Post: 03-13-2011, 12:48 PM
  2. p1133 and p1153
    By Kyle C in forum General Help
    Last Post: 07-26-2010, 05:55 PM
  3. p1153 p1133
    By redbird555 in forum External Engine
    Last Post: 05-12-2010, 06:52 PM
  4. P1133??
    By INeedLS1 in forum General Help
    Last Post: 10-22-2009, 03:14 AM
  5. p1133 help?
    By 2fast4u in forum General Help
    Last Post: 01-03-2008, 01:21 PM
