Results 1 to 10 of 10
Thread: Break problem on an old Ford
03-20-2011, 09:55 AM #1
My pops has a 79 F150. I changed all the breaks front and back along with the master cylinder, after driving it a few miles the front breaks tend to get stuck. Its like the caliper doesn't retract. Its fine when you first start driving but then afterwards they don't. Like at the moment, if I put it in gear the truck just stays put, you have to give it gas for it to move. WTF?? Bad Master?
03-20-2011, 09:58 AM #211 years of bangin gears
- Jan 2009
- North Jersey
Maybe air in the system? What fluid did you use to fill the master?
03-20-2011, 10:00 AM #3
03-20-2011, 10:01 AM #4
03-20-2011, 10:01 AM #5
Dot 3
I did a proper bleeding of the system I did have a lot of air coming out but kept bleeding it till a steady stream of fluid came out.
03-20-2011, 10:05 AM #6
I just checked the master cylinder, it is fu*king hot!!!
Im going to swap this out first and see if that is the problem. I don't think this should be hot at all.
03-20-2011, 10:09 AM #7
03-20-2011, 10:11 AM #811 years of bangin gears
- Jan 2009
- North Jersey
Sounds like you boiled the brake fluid and the heat got to the master.
03-20-2011, 10:43 AM #911 years of bangin gears
- Jan 2009
- North Jersey
You're going to have to jack up the truck and spin the wheels to see which one is binding.
03-20-2011, 11:04 AM #10Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Clogged compensation port in the master would be my guess
third break light tinting problem
By My00Z28 in forum Appearance SectionReplies: 5Last Post: 08-31-2011, 10:20 AM -
What Break's in 2005-2011 Ford Mustangs - Got An '05-'11 For
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-21-2011, 09:52 AM -
Engine Break-In Guide - Break-In Without Breakin'
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-17-2011, 09:40 AM -
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 03-05-2011, 02:20 AM -
check out this break dancer break
By pecha in forum Almost Anything GoesReplies: 4Last Post: 02-23-2009, 09:20 PM
