Results 1 to 20 of 28
    Apr 2010
    IN
    Removing interior
    How do you get the center consol out? I have all 5 bolts out. And it seems like theres a wire that connects to some random thing under the ashtray (ill probably cut that) and i have the shifter off. Cant seem to get it over the ebrake tho.
    And how do you get the backseat panel coat hangers off?
    And how did you remove the wire cluster under the passenger seat...it seems jammed. I got the driver side with no problem at all but dayumm the passengerside is stuck
    Help.
    Coral Springs, Fl
    Sunset Orange Metalic
    1. I'll have to take a look at mine again but i think the ebrake has to be all the way up, the wire could be to your ashtray light, not sure though. post up pics if you can.
    2. on the front of it there should be a little flap that flips out to get to whats holding it. A pick or something of that nature should help you out.
    3. Can't help with that one, camaro doesn't have an electric passenger seat
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Some one did a write up for the center console removal somewhere. Brb.
    The additional wire, if it's the ash tray light, should be really small/skinny compared to most of the cars wiring.
    I've never removed the power seat stuff, can you snap a pic of the harness?
    Bonner Springs, KS
    99 TA
    1. The center console...I assume you mean the lower half if you are having issues with the e-brake. Pull the e-brake up all the way and you will have to pivot the console piece (pull the rear part up and slide the console piece back towards the rear). I cannot remember the exact number of bolts, but 5 sounds correct. If you are not able to move the console easily, then you have some more bolts to remove.
    Not sure what the wiring under the ashtray would be besides to a light bulb. Is it an A4 or m6? There should be enough slack to lift the console alittle to see where it goes to and remove it without cutting.
    2. To remove your coat hangers, you have to pull out the center piece (the square piece). There is a slot along the bottom, you can use a screwdriver to pry it out, then just pull straight back to remove the center piece. Then the hook portion should come out easily.
    3. Removing the wiring under the passenger side...Are you trying to remove the harness that is located beneath the carpet? If so, its easiest to remove the trim along the door sill and lift up the carpet. Follow the wiring towards the center console and you will see it held down by a square piece of black-rubberish tape. It then goes over the driveshaft tunnel (might have to loosen the airbag sensor and e-brake bolts to remove the wiring) and then it is held on by another piece of rubber tape on the driver's side.
    I just removed my wiring about a month ago, but sorry no pics of the wiring in the car.
    Here is a pick of the wiring harness removed and the bottom of the seats. The wiring harness is below the seats on the carpet. The seat with the black box (lumbar motor) is the passenger side seat.
    Apr 2010
    IN
    Alright thanks i got it all out now. Got the headliner in and working on the carpet...which is a bitch. It didnt come precut so we have to guess and check. Ill be picking up some 3M carpet glue tonight and finishing up tom.
    Then its off to removing the catback and painting the calipers and rotors...
    Spring break=mod time
    Coral Springs, Fl
    sound fun, i gotta get around to painting my calipers soon. dont forget before and after pics
    Apr 2010
    IN
    Everythings out
    New carpet awaiting to get cut and installed...
    Apr 2010
    IN
    Headliner before (and i had NO VIsors!!!)
    grey
    And here ya go another b4...it was rediculous how dirty it was and stains like none other...oh and we found half a joint...my stoner friend verifie it...
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quite the project going on!
    Running new audio equip at all? Looks like a good time to run new wires.
    Coral Springs, Fl
    Perfect time to cut and reshape that hump on the passenger side floorboard
    Apr 2010
    IN
    Ive ran Memphis door speakers in both my cars. Didnt need to remove anything to install them in my firebird. And i said forget the hassel so i let dr. Dashboard put them in my ws6. Saved me a saturday. This summer im getting a new engine and a few goodies
    Money money money
    Orlando, FL
    Mean Black
    what do you mean to reshape? you mean to flaten it down? I kinda hate that hump.
    Coral Springs, Fl
    Exactly. I've always wanted to do it. I've seen it once before where someone cut out and welded in new sheet metal molded to match the drivers side
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    LOL, I don't mind the hump, probably b/c I have NEVER ridden in the passenger side...
    Member robs98mysticZ's Avatar
    Mar 2011
    Waynesboro, Pa
    Mystic Teal Metallic:320c
    1998 Camaro Z/28
    yea unless your riding in the pass seat the hump doesnt matter
    Coral Springs, Fl
    i got 2 friends with camaros and it bug the crap outta me
    whatever i can do to create a pleasant riding experience for my passengers
    Apr 2010
    IN
    thats what a V8 with headers is for
    ohh and boy do i have a bitchfit to throw when i finish this fucking project....
    I guess it's to late to suggest Dynamat sound proofing before you re-install the carpet.
    Apr 2010
    IN
    i see no point in dynomat unless the car has subs
    Coral Springs, Fl
    C5z28 went throught the trouble of that on his and he didn't get great results
  1. Camaro Interior Upgrades - Interior Design
    Last Post: 07-21-2011, 09:52 AM
  2. Camaro Interior Upgrades - Interior Design
    Last Post: 04-23-2011, 12:21 AM
  3. Removing The Interior Rear Hatch Covers
    By MAXX2 in forum General Help
    Last Post: 01-19-2011, 08:09 PM
  4. want to trade Charcoal interior for tan interior
    By DADillac in forum Parts For Sale / Trade
    Last Post: 03-28-2009, 07:56 PM
  5. Removing Interior part?
    By Bouvers in forum General Help
    Last Post: 05-14-2008, 11:49 AM
