Results 1 to 20 of 26
Thread: TrueTrac Axle Endplay
03-16-2011, 02:21 PM #1
Just rebuilt the entire rear end of my car a couple months ago, its a factory 7.5" 10 bolt. The original Auburn diff exploded so I replaced everything.
New parts included Motive 3.42 gears, Detroit TrueTrac diff, Moser axles, new c-clips, all new Timken bearings, and new seals.
The problem is there is excessive endplay in the axles, meaning there is too much clearance between the inner end of the axle shaft and the "spacer" inside the diff. So every time I come around a turn hard, the axles slide inward or outward, and often cause pad knockback.
Anyone else running a TrueTrac diff and having this problem??
The only solution I can think of is to have a machine shop make a new spacer that is wider so it takes up the excessive clearance between the two axles. They don't come in far enough for the c-clips to come out, but its enough to cause pad knockback and noise.
03-16-2011, 03:45 PM #2
That's weird. You can't shim the axles or use thicker C-Clips?
03-16-2011, 04:09 PM #3
03-16-2011, 05:23 PM #4
Not sure... maybe moser has them if they made your axles.
03-16-2011, 05:25 PM #5
Did you compare the Moser axle length with your stock axles?
03-16-2011, 05:44 PM #6
03-16-2011, 05:52 PM #7
03-16-2011, 05:54 PM #8
03-16-2011, 05:58 PM #9
03-16-2011, 06:09 PM #10
Yea they know their stuff.
The issue really has to be within the diff...regardless of axle length, ect.
The bottom line is that the center spacer is supposed to prevent the axles from moving inwards, while the c-clips are supposed to prevent the axles from moving outwards. The tolerance between all this should be very tight, not 1/4"-1/2" on each side lol!!
So either my c-clips are too thin (they are OEM size) or the spacer is too narrow.
Why this has happened, that is the puzzle I suppose.
03-16-2011, 06:16 PM #11None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I have the same setup as you, but I don't know the dimensions of the clips or the spacer off hand. I would suspect, as you have, that either the clips or the spacer is the wrong size.
03-16-2011, 06:20 PM #12Senior Member
- Apr 2008
- Madison, WI
Since it is a problem before and after, I'd guess the C-clips are worn out. Although I'll admit, I've never seen or heard of that. But they should be cheap enough to guess at. Either that or get a c-clip eliminators.
03-16-2011, 08:42 PM #13
Can you get C-Clip eliminators on a 10 bolt?
03-17-2011, 08:53 PM #14
I actually bought new c-clips already hoping that would fix the problem, same issue!!
After searching the internet, it looks like I'm not the only one with this problem. Apparently Moser axles have larger c-clip grooves than stock axles (didn't notice a visual difference when I installed them) and can cause excessive endplay.
One guy from 3rdgen.org went through many attemps to try and find a solution, and he ended up using external snap rings as spacer. Basically he put the snap rings on the c-clip groove and then inserted the c-clip next to them, with the snap rings closest to the end of the axle. The snap rings effectively take up the slack between the c-clip and its groove, allowing it to fit tightly between the side gear and diff spacer. Snap rings are made of "spring steel", and he reported that after extensive use they showed no signs or wear or fatigue. Looks like this may be the next thing I try to fix the problem.
As for c-clip eliminators, as much as I'd like to run them, I can't find a "street" version for the 7.5". They are all "drag race" versions, which means they are ball bearings instead of roller bearings and cannot be subjected to the side loading that the car would see on the street or road course. They make a tapered roller street setup for the 8.5" 10 bolt, but nothing for the 7.5"!! Too bad, that would be a nice solution!!Last edited by Wesman; 03-17-2011 at 08:58 PM.
03-18-2011, 03:17 AM #15
No reason the snap ring should not work and last the life of the axle. Certainly do not hear many good things about Moser on here.
04-07-2011, 05:48 PM #16Junior Member
- Apr 2011
- NW Arkansas
Black- 1967 Camaro
Just finishing up a 67 ss ragtop camaro with a 10 bolt 8.5" truetrac setup, 2001 LS brakes all the way around, Wilwood 7/8" bore manual brake setup.
I am having the same problem with excessive endplay.
Have stock axles with tight c-clips.
Without the cross pin any endplay is doubled because the axles are pushing against a floating spacer instead of the fixed pin.
This is causing excessive pad knockback which eats up most of the first brake pedal stroke after a hard s-curve.
Has anyone come up with a solution for this???
Thanks
04-07-2011, 06:29 PM #17Junior Member
- Apr 2011
- NW Arkansas
Black- 1967 Camaro
Just read a post on a jeep forum where an Eaton rep suggested welding up the axle ends and machining them to take up the excessive play???????????
04-07-2011, 06:30 PM #18
04-08-2011, 12:52 AM #19
04-08-2011, 12:58 AM #20
Dana S60...TrueTrac, Spool, or Detroit Locker which one?
By 98TransAmWs-6 in forum DrivetrainReplies: 50Last Post: 03-06-2014, 04:19 AM -
Posi Vs. Truetrac
By LeadFarmer in forum DrivetrainReplies: 1Last Post: 03-27-2013, 04:41 PM -
SLP axle back VS Borla axle back
By DVrec21 in forum External EngineReplies: 13Last Post: 01-05-2011, 03:45 AM -
Eaton Truetrac
By pajeff02 in forum DrivetrainReplies: 15Last Post: 12-22-2009, 01:42 PM -
New: Moser 9", TrueTrac. 3.50's, Strange drag brakes
By xssive in forum Parts For Sale / TradeReplies: 5Last Post: 07-05-2007, 01:42 PM
