Results 1 to 16 of 16
03-19-2006, 11:22 PM #1brianthomas7Guest
EU 700's, how much better than stock?
One of the subs in my sail pannel is blown and I have been searching for a replacement. From searching this site, it sounds like the EU 700 works in our cars with the factory monsoon system. I just wanted to hear anyone's opinion on how these sound compared to the stock subs. I am not excpecting them to be a huge improvement, just want to see if there is any.
03-20-2006, 07:12 AM #2Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
The other thread on this kind of answers that.
03-20-2006, 07:24 AM #3brianthomas7Guest
It really doesn't. All it says is that it is middy. That doesn't really offer me a straight comparison to the stock subs.
03-20-2006, 11:03 AM #4Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
he also said they sound under powered. If they make any sound then they are better than the stock ones.Right now they just sound kinda "middy" unless the volume is really low-then they sound really boomy
03-22-2006, 05:12 AM #5Detailing + Design
- Pittsburgh, PA
that was my thread.
i think the eu700's are iffy. i seriuosly have had to go through too much BS in order to get them to work, so my advice to you is stay with stock, or put in 2x10's or a stealth box.
03-22-2006, 02:48 PM #6Member
- Oct 2005
- Austin, Tx
Black/Black- 2000 Trans Am WS6 A4
the eu-700s should work fine... but most people that use them are probably scrapping the entire stock monsoon system anyhow... at least that's what I'm doing....
the Eu-700s are only $50, while the stock speakers are $85....
03-23-2006, 06:02 AM #7Detailing + Design
- Pittsburgh, PA
well it's come to this:
eu700's + 4 channel amp with front/rear crossovers so that the door mids don't try to keep up with the sail panels.
Elemental Designs makes a 4 channel specifically for this purpose; this is a direct quote from the E.D. Tech i've been chatting with.
it's not a monsterous amp, but it looks pretty inteligent; only $235.00
Originally Posted by E.D. Tech
03-23-2006, 06:15 AM #8Member
- Oct 2005
- Austin, Tx
that's exactly what I plan on doing... except you start running into problems with your headunit RCA outputs... because you want to cross everything over from there... you will hpf your doors, and the rear output obviously...
so the question is, do you sacrifice adjustability from the headunit and run the sail subs along with the hatch speakers... or do you run them with your REAL subs, at which point you have little control over the volume of the subs from the headunit, because the big subs can handle so much more...
if you aren't going to have big subs, then it's super easy to do this... but for most, it starts getting annoying... which is why there are now headunits with 4 sets of outputs... eD is even reselling one called the ural cdd....
03-23-2006, 07:51 AM #9Detailing + Design
- Pittsburgh, PA
oral what?
sorry...
i dumped my big 10's on my buddy a while ago. i was sick of the increased weight and toting them around all the time. i downsized to the eu700's but now i realized i need to "adjust" my whole system for them
03-23-2006, 09:17 AM #10Member
- Oct 2005
- Austin, Tx
"big 10s"?
okay...
03-23-2006, 09:41 AM #11Detailing + Design
- Pittsburgh, PA
i had 2x10's in my car before i downsized
03-23-2006, 04:27 PM #12Member
- Oct 2005
- Austin, Tx
hehe, I was getting at the fact that 10"s are small.... and you referred to them as "big 10s"
hey, maybe they were big for 10's and that would make sense...
every car I've ever owned, I've always had two 15s... so maybe I just can't see it from your point of view...
if I got the eu-700s, they'd just supplement the 15s in the rear... kinda flatten out response...
03-25-2006, 08:56 AM #13Detailing + Design
- Pittsburgh, PA
15's in an Fbody....do you hate your rear hatch?
03-25-2006, 11:58 AM #14Member
- Oct 2005
- Austin, Tx
not at all... and as long as you do some sound-dampening, you won't have rattles either.
in my 1990 Firebird, I put a peice of foam behind the license plate, and that was perfect... but the older f-bodys are more prone to rattles...
I just couldn't ever understand why people would go half-way and not finish up... if you want to big subs, why stop at 12s? unless they are brahmas or something, then normally the 15s would kick their asses...
if I can't build a decent dual-15 box, I MIGHT go with 12s, and use the brahmas.. but that's a big IF.
03-25-2006, 02:05 PM #15Detailing + Design
- Pittsburgh, PA
my 10's did me just fine. really, i miss them. but the weight reduction was a big +
03-25-2006, 06:18 PM #16Member
- Oct 2005
- Austin, Tx
yeah, I used to think 10's were pretty sweet... then I tried some 12s, and I was like, "holy shit!!"... then I figured, hey, why not 15s? and man, it was a world of difference... they effortlessly spit out the lows...
but for someone like you, maybe you could use the EU-700s, and somehow turn the sailpanel into some sort of ported enclosure? like the 3rdgens have... that may be a good solution for ya...
Stock headers, stock (GM) cats, y pipe custom fitted for LM1
By az gt eater in forum Parts For Sale / TradeReplies: 2Last Post: 11-20-2011, 08:26 AM -
LS1 Intake,Throttle Body, Gaskets, EGR, AIR, Stock Lid, Stock Manifolds
By WEZONIT in forum Parts For Sale / TradeReplies: 13Last Post: 10-11-2007, 12:48 AM -
FS: Stock 4-16x8 polished rims w/ stock eagle tires
By Long Beach in forum Parts For Sale / TradeReplies: 4Last Post: 01-24-2007, 10:11 PM -
By Long Beach in forum Western MembersReplies: 1Last Post: 01-24-2007, 09:15 PM
