Thread: Did the BCM repair,now what?
03-11-2011, 03:07 PM #1
For over 2 years I've owned the 2002 Z28, the drivers side window has intermittently not rolled up, down or stuck in between. Covinced it was the BCM, I pulled and repaired the solder joints, everything seemed fine when I put into Winter storage. When I pulled it out same problem as before. What does anyone think? Lack of ground to the window motor, bad window motor, bad window switch?
03-11-2011, 03:11 PM #2Member
- Cedars, Pa
White- '02 Camaro SS
Because the problem intermittent, the hardest to find and fix I would think a connection somewhere. Have you gone through and inspected / reattached all the wire connections?
BTW thanks for reminding me to do my BCM.
03-11-2011, 03:24 PM #3Electrical Engineer
- Jul 2009
- North of the Motorcity
So it goes completely out, or just slows down?
If it's going completely out, your sure it isn't the BCM, I would check the grounding first as well, then the switches. The motor slows down when it's going, I'm not thinking it's the motor.
03-11-2011, 03:28 PM #4
03-11-2011, 03:28 PM #5
03-11-2011, 08:44 PM #6Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Window motor is toast & needs replaced.
Heats up, stops.....cools for a few then works again til it heats up again.
03-12-2011, 05:18 AM #7
I will check the wires and grounds to make sure they are clean. It's very possible that the motor is going bad like mention before. The switch could be bad if the motor is completly stopping, not slowing down and then stop.
Like Rob said they heat up and stop working until they cool down.
03-12-2011, 06:46 AM #8
The speed of the window going up and down is fast, The temperature was about 40, so it wasn't overheating. The window just wouldn't go down. After about 10 minutes driving time, it worked fine. I also should mention that there is intermittent static in the drivers door speaker. I am leaning towards a ground problem. Any tips on pulling the door panel without destoying it?
03-12-2011, 07:47 AM #9
to remove the panel , 1st pop the cover that holds the power lock/window switches and unplug it out. Remove the small screw that holds the cover for the door handle. You have to grab the lock/unlock slide lock mechanism and slowly pull on it until the plastic piece pop out of the solid piece of metal wire. Disconnect the light bulb from the door handle cover. Remove the screw that holds the small black plastic triangle piece by the side mirror and remove it.
There are 4 screws that hold the panel down. One inside the area were you pop the cover of the switches. two underneath the handle rail, one in the front area and one in the back. The last one is at the bottom of where you can put stuff in the panel.
Once you have the screws out, hit the panel from the bottom up, like you are trying to slide it up. Don't pull back until you slide it up 1st. Once you slide it up you should be able to pull it out. you might have to gently move it to clear the tabs.
Instalation is reverse.
Linkage Assembly Repair - $1 Linkage Repair
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 09-28-2011, 05:50 PM -
Question: How Much For Repair?
By rbob93 in forum General HelpReplies: 16Last Post: 09-15-2010, 05:55 AM -
rim repair
By wildbanshee in forum General HelpReplies: 6Last Post: 02-04-2009, 04:24 PM -
Anyone know anything about spa/hot tub repair?
By DrMilhouse in forum Almost Anything GoesReplies: 2Last Post: 03-19-2006, 06:03 AM
