    Junior Member Jess2008's Avatar
    Feb 2011
    North Carolina
    2000 Trans AM
    Inner pannel cracked
    So i have experienced a new problem on my T/A. i was rolling up my passenger side window and it would not roll all the way up. so i took off the interior cover on the door and looked on the inside, i noticed that the fiber glass that the window frame mounts to is cracked and where the bolt that holds it in is now rounded out. so my frame is off so it keeps the window from rolling all the way up. fml. does anyone know what would be a good way to go about fixing this?
    Senior Member
    texas
    2000 formula
    pics?
    Join the PHK @ thephk.org Sommer86@6LE's Avatar
    Studio City, CA
    I mickey moused mine with zip ties....except my problem is worse......ALL 3 holes are ovaled out on my pass. door. I'm looking for a new door.
    Join the PHK
    2009 LS1.com Calendar Car
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by sjsingle1 View Post
    pics?
    Pics would def spark up some ideas.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    You might be able to span the crack with a metal plate riveted to the inner door.
    Otherwise you could try to repair it. The door is made out of SMC (Sheet Molded Compound). Its similar to fiberglass but traditional fiberglass repairs won't bond well to it. They also make/used to make jetski's from SMC so there are lots of guides out there on the SMC hull repair. The best product out there is made by WestSystem but there are others.
    West System
    Feb 2011
    North Carolina
    2000 Trans AM
    well i wanted to do a long term fix and also avoid buying a new door. its not terribly cracked yet, but if i let it go for to long it will def get worse. pics will be up soon
  1. Rear roof pannel issues
    By 98 Z/28 in forum Showcar and Detailing
    Last Post: 05-07-2010, 12:28 AM
  2. Help: Cracked oil pan.....
    By civenegas85 in forum GTO
    Last Post: 03-30-2010, 06:09 PM
  3. cracked rim
    By Train in forum Wheels and Tires
    Last Post: 02-01-2010, 09:09 AM
  4. Wanted: Front Bumper, F/D Quarter Pannel and Hood
    By Knighthawk LS1 in forum Parts Wanted / Trade
    Last Post: 06-16-2008, 01:51 PM
  5. Rocker pannel guards (?)
    By GLUMAKER in forum Appearance Section
    Last Post: 04-16-2006, 05:40 AM
