    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    steel pcv setup...
    so i was thinkin bout how my pcv setup looks pretty frankenstien, and i had the idea of using steel tubing....so what i got is 1/4" steel swagelock tubing and all the connections i need. does anyone see where i would have a problem using this? i have an abundance of this material at my disposal so i figured why not try it.....
    Senior Member
    texas
    2000 formula
    pics if ya do
    Wouldn't this be the same thing as a catch can? except it will be horizontal. I can foresee clogging issues. I could be wrong?!?
    Oct 2009
    pewter
    99 trans am
    well, thats why i posted the question. im not totally sure if it would work to my advantage. but its an idea, and i already brought home the material. it will still be the pcv setup, just in steel tubing instead of rubber hose.
    you could try it run it for say 50 to 100 miles, take off and see if it performs
    Retired Outlaw Sum Bitch
    Sure it will work. GM would use steel but rubber is cheaper.
  1. Man of Steel
    By SeVeReDiStOrTiOn in forum Almost Anything Goes
    Last Post: 06-14-2013, 01:26 PM
  2. Man of Steel
    Last Post: 04-17-2013, 05:52 AM
  3. Man of Steel
    Last Post: 01-03-2012, 08:31 PM
  4. What's plastic, what's steel?
    By azkass in forum Firebird / WS6
    Last Post: 11-09-2010, 06:00 PM
  5. WTT: My 4L60E setup for your T56 setup!
    By 4birdman in forum Parts For Sale / Trade
    Last Post: 03-16-2007, 12:26 PM
