Thread: AEM Products
02-27-2011, 02:23 PM #1Member
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
AEM Products
Has any one used the products below? If so would you recommend them for me to use?
AEM water/meth kit
http://www.aemelectronics.com/water-...ne-engines-51/
AEM Wideband Uego
http://www.aemelectronics.com/wideba...fuel-gauge-25/
AEM tru-boost gauge/controller
http://www.aemelectronics.com/tru-bo...ller-gauge-757
Thanks for your responses
03-02-2011, 05:34 AM #2
The water/meth kit is pretty chintzy... I only recommend Alkycontrol.
Their wideband is pretty much the bottom of the barrel for consumer-level units. It has no free air calibration, it does no signal averaging at all... it's output is extremely jumpy. For tuning, it's no good at all. If you are using it just to monitor it's ok, but you are still better off with something else. Since it has no free air cal, in order for it to be even close to accurate, the sensor needs pretty regular replacement.
The boost controller works pretty well and is quite affordable. I wouldn't use it on a big HP setup but for under 800rwhp or so I am sure that it would work well.
03-02-2011, 09:50 AM #3
03-03-2011, 09:08 PM #4
I like the NGK AFX quite a bit...
03-04-2011, 01:25 AM #5Member
- Apr 2009
- Pennsylvania
03-04-2011, 06:17 PM #6
I tune with it. I don't mount it in any cars.
so many products...
By transAMchubby in forum Showcar and DetailingReplies: 31Last Post: 11-05-2007, 05:05 AM -
new products
By 1MileCrash in forum Showcar and DetailingReplies: 5Last Post: 05-12-2007, 10:17 AM
