Results 1 to 10 of 10
Thread: WELD your Subframe Connectors!
02-27-2011, 06:10 AM #1
I have had (BOLT ON) 3 point UMI Subframe connectors on my car since August 2007. They definitely made a difference. They tightened the whole car up and I noticed less squeaks and rattles (especially the T-tops). I also noticed that when I would put the car on a 2 post lift, the doors would open and close much easier vs. before they felt like they were miss aligned.
Last night I welded the subrame connectors on and took it for a drive down some rough roads. I heard no rattles from the T-tops and no squeaks. It was a total night and day difference. I can now put the car up on the lift and the doors will open and close the same as they would if the car was on all 4 wheels.
Just make sure you guys weld the subframe connectors on while the suspension is loaded (car on all 4 wheel).
02-27-2011, 02:28 PM #2Senior Member
- Jan 2010
- texas
silver- 2000 formula
i have not noticed my SFCs moving around.......took them off not to long ago and there was no signs of movement.........glad i was able to take them off
02-28-2011, 12:10 PM #3
02-28-2011, 03:32 PM #4Senior Member
- Jan 2010
- texas
i took them off when i drilled out the front bolt hole for the LCAs to 1/2............the UMI SFC holes were already 1/2 as i found out......but still it was good that i could remove them
02-28-2011, 03:58 PM #5
No question that welding them would add to the structural integrity. I just don't want to mess up the pretty underside of our car.
03-01-2011, 02:59 PM #6
I hear ya. I guess that I am addicted to the, no squeaks solid chassis that now handles like is got a full frame. The car feels totally solid and now I can say that having them bolted on allowed a lot of flex.
03-01-2011, 03:42 PM #7
you can't beat the handling and feeling of a solid chassis car. I love my SFC as well.
03-02-2011, 05:14 AM #8Junior Member
- Nov 2010
- Upstate Ny
- 99 Formula
i want the uni bolt on 3 points but i have mac headers and y , will they fit fine together?
03-02-2011, 06:28 AM #9
I just have the 2-pts so mine never get in the way
Never been in a car with bolt-on SFCs so I don't know how that feels, but I know with my current set-up, my car feels 100% solid.Boost gets you laid, unless your name is Jon.
03-02-2011, 07:06 AM #10
3 point subframe connectors do not get in the way of anything. There are very few brands out there that might not be designed as good as the UMI or BMR. I have run some pretty crazy exhaust systems on my car and not one time was the SFC in the way.
Looking for subframe connectors Prefer Edelbrock Weld in
By 71-Camaro-98 in forum Parts Wanted / TradeReplies: 3Last Post: 04-14-2011, 01:20 AM -
For Sale: NEW weld-in tubular subframe connectors $90
By JAGUAR5822 in forum Cowhands, Local Parts and Fish BaitReplies: 0Last Post: 09-08-2008, 06:38 AM -
Subframe Connectors
By egod in forum Suspension and HandlingReplies: 23Last Post: 05-15-2008, 04:31 PM -
Subframe connectors, weld vs bolt
By kool-aide in forum Suspension and HandlingReplies: 72Last Post: 11-10-2007, 03:51 AM -
subframe connectors
By Sweet Lou in forum Firebird / WS6Replies: 6Last Post: 06-06-2006, 11:46 AM
