Results 1 to 18 of 18
    Orlando, FL
    Mean Black
    Correct airlid instalation and easy fix to keep clips down
    A suggestion for those having issues with the airlid clips. Just mold the tips of the cable ties like pictured to get around the plastic tab. Then cut the excess. Works great. Beats buying new clips and it will hold them down no matter what. You just need 2 small cable ties. Enjoy.
    UPDATE: go to the bottom of the sticky for correct airlid install pics.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Not a bad idea!
    I just bent mine, but a black zip tie would a good idea.
    Orlando, FL
    Mean Black
    Quote Originally Posted by KMdef9 View Post
    Not a bad idea!
    yeah I used green because i got tons of them. I guess you can use your favorite color.
    Senior Member
    texas
    2000 formula
    glad my KN kit does not use clips
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    Good idea. those things are like duct tape. always another use.
    I used a die grinder on mine a while back. If you cut the slot a little deeper they stay too.
    Orlando, FL
    Mean Black
    Quote Originally Posted by Z28_Driver View Post
    yeah i can't live without duct tape or cable ties!
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    The front of my factory lid was a mostly duct tape and rtv until a got an slp lid. It just kept cracking and I would add another piece of tape.
    The cable ties are a lifesaver. the very thick type will even hold exhaust pipe up for a few miles when a hanger breaks.
    Two must haves for anyone with a car.
    Sticky Nom
    stuck....thanks for posting this. This question shows up a few times a year it seems.
    Orlando, FL
    Mean Black
    Woohoo sticky
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Congrats on the sticky!
    Orlando, FL
    Mean Black
    thanks.
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Not to drag up an old thread...but first problem it appears is the lid is set over the top of the bottom piece and that is why the clips do not stay.
    The front LIP on the LID should fit inside/behind the bottom piece attached to the car!
    Orlando, FL
    Mean Black
    Quote Originally Posted by bryceslu View Post
    Bryceslu is correct. But this trick can help those even with the lid installed correctly.
    Make sure your lid is installed correctly:
    Incorrect: (the bottom of the lid is sticking out of the base)
    Correct: (the bottom of the lid is sitting inside the grove on the base)
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    hahaha..
    i was going to comment on the first pictures where the airlid lip was outside of the box. but i see someone already pointed it out. i was having trouble with these stupid clips for this same reason.
    then i was like....
    Orlando, FL
    Mean Black
    Quote Originally Posted by jsmith564` View Post
    hahaha..
    then i was like....
    yup it took me like a year to figure it out and it was by accident lol. I was told it was wrong but i was like huh? and then when I figure it out I was like ohhh.... dummy.
    Chicago, IL
    00 NHRA Formula
    Nice pics! should get the point across to some of the other lesser enlightened members out there
    Orlando, FL
    Mean Black
    like me lol!!!
  1. Question: Lower and upper control arm bushing removal and instalation
    By JayTA98 in forum General Help
    Last Post: 10-18-2013, 05:03 PM
  2. Question: radio instalation kit
    By ls1ws6ben in forum Stereo and Electronics
    Last Post: 01-04-2011, 08:28 AM
  3. Crazy clips "Trans Am, Firebird, Camaro video clips"
    By Richy_Rich67 in forum Firebird / WS6
    Last Post: 02-13-2008, 06:52 PM
  4. airlid clips
    By mrr23 in forum Appearance Section
    Last Post: 07-04-2006, 04:25 PM
  5. Header instalation procedures
    By SleeperZ28 in forum External Engine
    Last Post: 05-27-2006, 09:43 AM
