Results 1 to 11 of 11
Thread: redlining
03-18-2006, 10:24 PM #1
- Feb 2006
- california
redlining
How many times can a basically stock ls1 hit the rev limiter before you start to have problems. The car in question is a '98 m6 z28 with mti lid, hyper tech III tune, msd wires and 4.10's. I run it pretty hard and have been into the red a few times only hitting the limiter twice for maybe a half second, with the 4.10 gears 6k+ comes pretty fast and I don't want to bend a valve or run lean or something worse.
03-19-2006, 06:10 PM #2
The limiter is there for a reason...so as long as you don't raise it or live in the redline you shouldn't have any major probs. But just like anything else in life...the harder you beat something the less life you're gonna have out of it.
03-19-2006, 07:29 PM #3
Originally Posted by SeVeReDiStOrTiOn
Just shift a little early until you get used to how fast it hits redline. Running lean won't be a problem. On a stock motor, it's close to impossible to go lean by merely pulling high revs, especially since you've got a 98 with bigger injectors. Moral of the story: try not to hit it, but if you hit it briefly a couple times, don't worry aboot it.
03-19-2006, 08:17 PM #4
Invest in a shiftlight of some kind if it concerns you. Try to set it about 5500 to give you time to react to the light and shift before it hits the limiter.
Part of the problem is that these tachs usually resond slow, especially in first gear and even more so after adding 4.10's. Just resist the temptation to crank up the limiter with your programmer....Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
03-19-2006, 09:54 PM #5
Originally Posted by hammertime
03-20-2006, 06:19 PM #6
- Feb 2006
- california
a shift light seems like the best solution, i just dont want a huge light sitting on the dash. I think i saw a post about where to hide one of those small raptor shift lights so i think im gonna go that route.
03-24-2006, 07:28 AM #7
- Oct 2005
- Arnold
Black- 2000 SS
http://www.installuniversity.com/ins...ht_install.htm
this is what i did cause i did not want to see the light everyday.
03-24-2006, 11:21 AM #8
You can also get just a stand-alone shift light and attach it to the side of your a-pillar. I've got one attached to my gauge pod there, and it's right where you can see it while still looking ahead, but it doesn't obstruct your view of the road.
03-24-2006, 04:25 PM #9
- Feb 2006
- california
Originally Posted by SSJoe15
03-24-2006, 04:32 PM #10
- Feb 2006
- california
what kind of shift light is that in the write up? it says matthew harlan but nothing comes up when i do a search.
03-25-2006, 09:41 AM #11
- Oct 2005
- Arnold
Black- 2000 SS
http://www.harlan-engineering.com/store/store.html then click on shiftlight on the upper left.
