Thread: Its been a long time coming!
02-20-2011, 03:22 PM #1
- Mar 2009
- indianapolis
PBM 366ci TC78 E85- 2004 Pontiac GTO PBM A4
Well, its been a long time coming!
Its been since August(ish) since ive heard my car run, so i spent this weekend doing what ive needed to get done. And i did, the turbo is not mounted on yet only because i want to take a grinder to the inside of the flange to clean some stuff up first.
And i always run it open first to make sure their is nothing that will ruin my turbo.
It appears to be smoking because i always soak the heat wrap in water to help it tighten after a few heat cycles.
Anyway, here is a few pics of the progress then the BLAM! Start up!
To all of you that have come over and helped or lent me tools to make this process possible, thank you!
I hope to have her road worthy in about 2 weeks. Mark, i hope your ready brother!
02-20-2011, 03:40 PM #2
Nice! Subscribed for more pics and vid.
02-20-2011, 03:45 PM #3
- Retired Outlaw Sum Bitch
Good man! I do the same with my heat wrap. Smokes and stinks all to hell
02-20-2011, 04:20 PM #4
- Mar 2009
- indianapolis
Just a quick question, first start up, took about 3 seconds to build oil pressure, but climbed the entire time from start up, leveled off at about 42psi and stayed their, didnt rev it, but it stayed at 42psi.
thats a good pressure right? im thinking yes/.
02-21-2011, 08:19 PM #5
Looks sweet man. Do you think you should also wrap your coolant hoses?
02-22-2011, 06:16 PM #6
- Mar 2009
- indianapolis
Def. Wrapped them with a reflective heat wrap today while i had the hotside off and adding copper silicone rtv to the vbands. Things are moving along nicley now,
oil supply and return are plumbed and saw my blades spinning under exhaust power tonight, very exciting
Long time listener, first (or second) time posting
By Norrie in forum New Member IntroductionsReplies: 4Last Post: 08-04-2008, 08:10 AM -
first time posting, long time reading
By bamaballa205 in forum New Member IntroductionsReplies: 3Last Post: 06-01-2008, 12:45 PM -
Long time reader first time poster
By bigmarky in forum New Member IntroductionsReplies: 2Last Post: 05-27-2008, 05:47 PM -
Long Time Listener 1st Time Caller
By NSSTG8TR98 in forum New Member IntroductionsReplies: 6Last Post: 12-21-2007, 06:33 PM -
Long time guest first time member
By strebej in forum New Member IntroductionsReplies: 2Last Post: 08-08-2007, 07:19 PM
