Results 1 to 20 of 36
02-16-2011, 09:16 PM #1Junior Member
- Nov 2010
- Rarden, Ohio
Navy Blue Metallic- 1999 Trans Am Formula
"TCS OFF" "ABS INOP" lights come one for no reason...?
I have a 1999 Trans Am auto. When I first start up the car there are no lights or any issues that come on. I'll get down the road a little ways and all of a sudden, my TCS OFF and ABS INOP light up on my dash. Any suggestions where to start diagnosing a problem?
BTW... i push the TCS button and it will not respond and the light is off.
02-16-2011, 09:19 PM #2Just me
- Nov 2006
- Broken Arrow, OK
Have you changed tires recently?
02-16-2011, 09:21 PM #3
Check the wheel speed sensors ( I think that's what they are called), small sensors behind the wheel/brake caliper area. One of the wires might be torn or almost tearing and that's when the pcm doesn't read it then it sends off the signal and those lights come on.
02-16-2011, 09:27 PM #4Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
It could be a speed sensor. Or the ABS block. Mine had both problems.
If you are running bigger tires
Or you went for gears on the rear end.
That could be the reson,00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
02-16-2011, 09:31 PM #5Junior Member
- Nov 2010
- Rarden, Ohio
It was ran off the road and could have had something pull or tear the sensors. I will check tomorrow and see if anything looks unusual.
02-17-2011, 02:22 AM #6Senior Member
- Nov 2006
- Indianapolis
Wheel speed sensor/wiring is the vast majority of this cause. Just have to find out which one. Should be a relatively easy fix.
02-17-2011, 02:27 AM #7
on my last car i had the brake inop light come on and it turned out being a brake hose that was torn and leaking...
02-17-2011, 02:35 AM #8
02-19-2011, 09:29 PM #9
it means go fast.....right now
04-03-2011, 03:49 PM #10
mine came on today after going over a rough patch of asphalt.i guess i should check the rear wheels first or does that not matter?
04-03-2011, 04:54 PM #11now greybat66
- Apr 2007
- bloomfield nj
Red- 1998 trans am
i had my abs lights go on and i spent a fortune on a 1997 transam convertible that i had.The problem was the wire of the speed sensor please check that before anything, good luck.
04-03-2011, 08:56 PM #12REAPER Z28
- Apr 2009
- Tyler TX
Navy Blue Metallic/Black- 02 camaro z28/01 wife t/a
mine does the same thing. i just both a 01 trans am and wen i drive for a bit out of nowhere my tcs light comes on and the brake light and abs light. Also wen this happen's my tcs button does not respond. If you find the problem please let me know what it was.
04-04-2011, 08:32 AM #13
Has anyone had their car checked with a brake scanner? The codes will not report on a regular scanner. I would head to the local parts store while the light is on and see if a code has been set.
04-04-2011, 08:38 AM #14
I scanned it with my basic scanner and got no codes.advance and the zone use the same scanner I have so I didn't bother with them
Posted via Mobile Device
04-04-2011, 09:58 AM #15dbl clutch'n like i shld
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
had the same problem a few days ago it ended up being that the bolt that holds the ground down on the dr. side front fender was loose. i tightened it up and havent had a problem since
04-04-2011, 12:20 PM #16Army of 1
- Nov 2006
- Alachua, Fl
Ignition Orange/Black- 2008 G8 GT, 98 Z28 383
Mine did this intermittently for the entire time I owned the car... I never did figure out why it was doing it. Didnt really bother me though. No codes with a scanner here either. And even though my ABS light was on the ABS still worked.
04-04-2011, 01:31 PM #17
04-04-2011, 02:25 PM #18
check the speed sensors. the dealership has a scan tool specifically to read them. it will tell you which one(s) are bad.
since the speed senors are discontinued, you will have to splice in the new connector to the one that came on the car. the guy at the parts desk can help you with that. take in the entire connector for reference. costs like $20 per connector (so no more than $80 if all 4 are bad). i had to do this to my '98 Ws6 that I used to have (passenger side front was bad).
it's pretty simple and straight forward.
04-04-2011, 08:52 PM #19
One thing to check is how much brake dust is built up on the sensor. Pull the 10mm bolt holding the sensor in and pull the sensor out. Clean it up and stick it back in. Too much interference with the magnetic sensor will cause it to misread.
Mine now trips only when I'm going down the interstate over long distances but that's because I've changed the rear, upped the gear, and put bigger tires on it. Tried my damndest to keep it close but evidently its just enough to trip both lights.
2000 Pontiac Firehawk #0041 of 742
04-05-2011, 03:19 AM #20
Mine comes on and off. I read the codes with HPT and got 4 "restraint" codes. I can't remember what they all were, but one was a l/f speed sensor. Hasn't come on in three days, so not really concerned.
Another "Hate Crime" is a Hoax: "Victims" were Perpetrators
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 02-26-2016, 04:52 PM -
Hussein Obama: Opponents to Iran "Deal" are "Crazies"...
By wileyCoyote in forum Political / Debate ForumReplies: 4Last Post: 08-26-2015, 11:11 AM -
Obama "Admits" to "Long Term Campaign" Against ISIS...
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 07-06-2015, 04:01 PM -
Hard Left in Knots over "Wacist" Prism of "Cat Call" vid
By wileyCoyote in forum Political / Debate ForumReplies: 0Last Post: 10-31-2014, 04:07 PM -
Weather Channel Co-founder: "Climate Change" is "Not Valid"
By wileyCoyote in forum Political / Debate ForumReplies: 7Last Post: 10-24-2014, 05:44 AM
And you didn't notice anything bad with the brake pedal? Must've been a real small leak.
