Results 1 to 14 of 14
    Aug 2010
    Parkville, Maryland
    2002 Camaro SS
    02 SS Dogtracking
    I got my 02 aligned today and they told me the rear is dogtracking, but the car was never hit. Did carfax and came up clean. Could this be a factory defect? Maybe something bent? Cant put a uni-body on a frame straightener. The guy say the total toe in the rear is 0 so the tires won't wear, but I don't want it running down the highway sideways. Has anyone else experienced this?
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Only way that is possible is if it was hit. They give you a printout of the final alignment? There is a spec for thrust angle that could be off if it was hit, adjustable lower control arms could fix that depending on the extent of the damage.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by 02 CamaroSS View Post
    yes you can. Show us the alignment printout if you can. Another option is to take it to a body shop, tell them the problem and ask them to put it on the frame rack and measure it. They can determine how straight the body is.
    Aug 2010
    Parkville, Maryland
    2002 Camaro SS
    My friend's father owns a very well known body shop and he said u cant pull a sub frame car. If u think about it, if u try to pull a uni-body u will pull it apart where they come together.
    Bay Area
    my highbeams
    What you posted again w/o the specs?
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    So how do you think they straighten them out when they get wrecked?
    Aug 2010
    Parkville, Maryland
    2002 Camaro SS
    Here r the specs from the alignment .
    Madison, WI
    2001 Silverado Z71
    Quote Originally Posted by 67CamaroRSSS View Post
    Exactly
    Madison, WI
    2001 Silverado Z71
    Ok hold on here, let me turn my laptop upside down so I can read those pics......
    I'd say no its not really dogtracking. The numbers show that the rear axle isn't exactly centered side to side in the body but you can check most F-bodies and find the same thing. Mine is off by about a 1/2 inch. The rear is also pointed off to the left side more then it should be.
    You can fix that (the rear toe/trust angle) with adjustable lower control arms. You can also fix the side to side centering if you want with an adjustable panhard bar.
    Aug 2010
    Parkville, Maryland
    2002 Camaro SS
    Thanks. That marks me feel A LOT better.
    The Demon Demon_Z28's Avatar
    Feb 2008
    WA
    Bright Rally Red
    yea mine isn't perfectly centered either and I have an adjustable pan-hard bar as well.
    Bay Area
    my highbeams
    My head doesn't turn that far
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Wink
    I respectfully disagree, years ago I had the rear leaf springs beefed up at a spring shop on a 1976 Camaro, and they never centered the rear axle, that is it was "cocked" slightly, it turned out that the rear axle was off by 13 degrees, and the alignment shop could not properly align the vehicle.
    SteveC
    Aug 2010
    Parkville, Maryland
    2002 Camaro SS
    Looks like I'm purchasing adjustable lca's and panhard bar.
  1. FS: Hunting dogtracking equipment
    By BBBBadSS in forum General Classifieds
    Last Post: 02-02-2006, 01:47 PM
