Results 1 to 20 of 24
02-16-2011, 06:44 AM #1
What do you use to lubricate weather stripping, etc?
I've heard/read that I should be lubricating weather seals, t-top seals, window seals, etc. to prevent drying and cracking. Lubricating with what? I don't think crisco, hand lotion, or wd-40 is what people have in mind. I've seen references to GM part#12346241, super lube, is this it? If yes, is there a generic equivalent? Is there a product at an autoparts story I should seek?
02-16-2011, 09:58 AM #2Senior Member
- Jan 2010
- texas
silver- 2000 formula
dielectric grease
02-16-2011, 10:14 AM #3O U 8 1 2
- Nov 1999
- over here...
i use black magic tire shine on mine...
02-16-2011, 11:27 AM #4Junior Member
- Feb 2011
- Suffolk, Va
- Blog Entries
- 1
Sebring Silver- 1998 Corvette
02-16-2011, 12:19 PM #5Member
- Cedars, Pa
White- '02 Camaro SS
303 Protectant
02-16-2011, 01:33 PM #6Junior Member
- Feb 2011
- San Jose
- 2006
WD40. A real lite rub with a clean silicon grease works good as well. Don't use to much as it can rub off on clothing.
02-16-2011, 02:06 PM #711 years of bangin gears
- Jan 2009
- North Jersey
I've used silicone spray.
02-18-2011, 03:18 PM #8
02-19-2011, 07:31 AM #9Member
- Tulsa,OK
Quick Silver- 2002 Z06
Silicon spray is silicon based and is a lubricant/sealer
WD40 is mainly a water displacement/rust eater that "kinda" lubricates. A good silicon spray is quite a bit better IMHO.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
02-19-2011, 07:56 AM #10
Spray silicone on a rag and then wipe the rubber seals on your car with the rag.
03-15-2011, 04:17 PM #11
03-15-2011, 05:37 PM #12
I use Wurth rubber care. I heard about it from my paint and body guy. They have allot of car care products and so far a like all that I have tried. I tried the dupont silicon in the winter to keep the doors from freezing shut and it worked pretty good. I use the Wurth when I have time to go through and detail all of the trim and rubber. It's not cheap though.
03-15-2011, 05:48 PM #13
" I've turned more dish cloths into shop rags this month than I had planned."
Funny ^^^^^^ Been there.......
Rub them down with a silicone dielectric grease and your're good to go.....
Ask any auto parts store and they should be able to help you..2000 NBM WS6
/oo_________oo\
|==_/_ws6_\_==|
><(((º>´¯`·.¸¸.·´¯`·.¸¸><((((º>
03-23-2011, 07:33 PM #14
i use mothers "back-to-black", ..apply about once or twice a year.
03-24-2011, 07:39 AM #15Member
- Tulsa,OK
I went to our local AutoZone and they did not stock the back-to-black. Nor did they have any input on what to use or if they sold anything. Waste of time to even ask
I'm going to go pick up some of that 303 products stuff at a local boat store. The reviews on the net about it are great!
03-24-2011, 08:42 AM #16
Gm superlube it what we use at work, they also recommend dielectric grease because it has silicone in it. the superlube has ptfe in it
03-24-2011, 09:09 AM #17Electrical Engineer
- Jul 2009
- North of the Motorcity
Count another vote for silicon spray.
03-24-2011, 09:41 AM #18
Just get something with silicone
03-24-2011, 12:38 PM #19Spaz is My Mentor
we're suppose to lube the weather strip?
Damn it, another thing to add to my shopping list.
03-26-2011, 01:57 PM #20
Does todays Armorall have silicone in it ?????????
Weather Stripping at the top of the windshield
By theorangeguy in forum Appearance SectionReplies: 3Last Post: 07-12-2014, 07:14 PM -
Question: Weather stripping
By SS201 in forum Camaro / SSReplies: 11Last Post: 02-04-2011, 04:34 AM -
Help: looking for the door weather stripping..
By claytonr in forum Firebird / WS6Replies: 5Last Post: 02-18-2010, 08:26 AM -
help with weather stripping
By T/A 2001 in forum Appearance SectionReplies: 7Last Post: 08-06-2008, 05:52 AM -
93-02 weather stripping?
By SpyderLox in forum Appearance SectionReplies: 1Last Post: 03-20-2007, 02:09 PM
