Results 1 to 20 of 20
Thread: Question on gears
02-16-2011, 05:34 AM #1Junior Member
- Feb 2011
- Ohio
White- 2001 Z28
Question on gears
Ok i'd like to put a set of 3.73's or a set of 4.10's in my 01 but do i have to tune for them to make sure the speed o will read right?
02-16-2011, 06:08 AM #2
you dont have to. but if you dont your speedometer will be off and that messes up your odometer and you will be racking up more miles than youre actually driving
02-16-2011, 08:06 AM #3
Are you an a4 or m6?. a4's require tuning after a gear change to shift properly.
02-16-2011, 09:56 AM #4
i think he is an a4, his name is 01a4z28 lol
02-16-2011, 05:46 PM #5Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
Assuming you're an A4,which gears do you currently have,2.73s' (GU2) or 3.23s' (GU5) ?
what part of Ohio are you in ?
02-16-2011, 05:53 PM #6Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
If it's an auto. 3"42 or 3'73s
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
02-17-2011, 11:24 AM #7
I was told you dont need to have a tune to get it to shift properly, only the speedo will be off. That is from a tuning "expert".
Can I ask where you got that information from? I am not calling you out or anything just curious.
Good call. I just got a set of 3.73s.
02-17-2011, 11:27 AM #8
A4 cars have MPH based shift points I believe. A large enough gear change could affect this.
Probably affects the TC lockup also?
02-17-2011, 11:39 AM #9
02-17-2011, 12:27 PM #10King 0f n00bz
- Jan 2006
- Shepherd, Michigan
what are you looking for your car ? people get so scared with autos and gears...if you are doing drag strip ..dont be afraid of 4.xx ..my lord we have a order drive gear ...if you are on the street look into 3.73 to 4.10
02-17-2011, 12:34 PM #11Member
- Staten Island, NY
2007 Cadillac Escalade- 98 Camaro SS, 09 G8 GT
I have 4.10's in my auto street car. I can daily drive it without issue....I run about 2600 rpm at 70 on the highway.
02-17-2011, 12:44 PM #12
Only thing that scares me of the gear change is that some people break the rears out. I dont think I am pushing any huge amount of power I just wanted a little extra for the street and the 2 or 3 times a year I plan to go to the drag strip.
02-17-2011, 01:08 PM #13
02-17-2011, 01:11 PM #14King 0f n00bz
- Jan 2006
from a 3.73 to a 4.10 is only about 10% more torque "increase"
02-19-2011, 03:30 PM #15
02-22-2011, 06:24 PM #16
Sorry for the late response!
Very true, less "shock" at launch. I have a stock converter so I will try to just leave around 1600-1700 like last time.........unless my car breaks loose earlier which it might do...lol
Where do you start to get that chawing when you are braking it and hitting the gas?
No doubt. I am going from 2.73 to 3.73 and YES I am getting a re-tuned pcm to compensate for it. I feel it necessary.....I want a correct speedo and no issues what so ever.
02-22-2011, 07:02 PM #17Junior Member
- Feb 2011
- Ohio
White- 2001 Z28
02-22-2011, 09:45 PM #18
02-23-2011, 05:35 AM #19Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
since you're 2.73s' which has a 2 series carrier,you'll need a 'thick' set of gears,unless you get a 3 series carrier (from a 3.23 or 3.42 rearend).
I'm 4.56s' in an A4 and spinning 2500rpm at 60mph,changing your ratio from 2.73s' will give you
-1775 rpm @ 60mph with 3.23s'
-1875 rpm @ 60mph with 3.42s'
-2000 rpm @ 60mph with 3.73s'
-2250 rpm @ 60mph with 4.10s'
you will need a 'tune' to correct speedometer and shift points,but not the type of 'tune' that is associated with a dyno tune,just find someone that has a laptop tuner with 'open' license.
changing from 2.73s' to 3.23s'/3.42s' would be much cheaper/simpler by just swapping in a complete 'take-out' rearend. If that were the case you would need to make sure you got a 'channel compatable' rearend. You didn't state if you're 3 channel ABS or 4 channel ABS & Traction Control.
Most will upgrade their convertor first(before gears) for perfomance.
02-23-2011, 07:02 AM #20
Question on gears
By imprtkillr2810 in forum Firebird / WS6Replies: 4Last Post: 11-28-2012, 11:12 AM -
question on gears
By racingrev in forum DrivetrainReplies: 15Last Post: 06-20-2009, 02:05 PM -
Question on gears
By One_Bad_TA in forum DrivetrainReplies: 3Last Post: 11-05-2008, 07:51 PM -
Somewhat new and Gears Question?
By pipes_ta in forum New Member IntroductionsReplies: 5Last Post: 10-01-2006, 01:45 PM -
Question about gears
By M6TA in forum DrivetrainReplies: 3Last Post: 04-20-2006, 12:52 PM
