    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    gas pedal hard to push on 98 trans am
    Well I have a 98 trans am and its been idleing up and down and the gas pdeal is hard as hell to push down! Does anyone know what's up with this and what's goin on??
    park bench
    gmcheviac
    Might be a seized throttle body or cable
    Aug 2006
    academy,tx
    1996 Trans am
    I don't know what it is, what is the idling up and down bout?
    sounds like you could have a couple things going on. First thing I would do is clean the throttle body really well. I'd take it off the manifold (no gaskets to replace) and clean it really good. If it's all cruded up it could cause both the issues you have. Another option is an issue with your cable and a vacuum leak or something along those lines. Clean it first and report back.
    Aug 2006
    academy,tx
    1996 Trans am
    Is it hard to take the throttle body off?
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    It's very easy to remove the TB.
    My car had the same problem.
    I cleaned the tb it helped a little. I changed the tb now it's way better than before.
    I got a ported tb.
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    Quote Originally Posted by camarostripes96 View Post
    basically just 3 bolts plus a couple plugs and the coolant lines that run through it. Would be a good time to do the coolant bypass while you have it taken apart.
  1. Burnout at the track causing hard clutch pedal.
    By Kramsdell in forum Manual Transmission
    Last Post: 11-18-2011, 06:31 PM
  2. Gear shift button extremely hard to push when in park
    By Zimbabwe_3 in forum General Help
    Last Post: 06-26-2008, 06:01 PM
  3. 1976 Pontiac Trans Am Clutch Pedal - Bearing Down For Action
    Last Post: 01-30-2007, 08:30 AM
  4. Manual pedal set from a 98 trans am looks brand new
    By thebrownone in forum Parts For Sale / Trade
    Last Post: 01-22-2007, 07:22 PM
  5. Hard brake pedal when wet/rain out side?
    By tx77015ls1 in forum General Help
    Last Post: 12-27-2006, 04:30 PM
