    hello blindboy2k1's Avatar
    pittsburg,CA
    fuel in cylinder head intake port?
    after my cam swap a few days ago the car seemed to idle ok... i drove it once and it was in limp mode and i had a coolant keak , needless to say , i spotted the leak and its from the head gasket (very back headbolt was not torqued down all the way , my mistake) after tightening it , still a leak .
    so i decided to replace the head gasket and bolts , since i figured they are tty to useing new ones after removal would be ideal for a safe bet.
    After takeing off my intake mani , i noticed cylinders 3 and 5 have a very good amount of what looks and smells like gas inside of the intake chamber of the head.
    i have never had to deal with this problem , and after a quick search could not find an answer. Do i have a lifter issue ? spark ? bad coil pack ? valve ?
    pittsburg,CA
    found my problem , i feel kinda stupid for not looking into it before i posted, after lifting my valve covers my 3rd and 5th cylinder rockers on the intake valves were pretty loose.
    a quick re torqueing and turning the motor by hand and torqueing again solved the problem
    You have to be systematic when working on a car. I frequently stop during an installation or maintenance procedure and I touch my finger to every nut and bolt while chanting "tight-tight-tight..." Meaning I know that I have tightened or torqued that particular fastener. If I get to one that I am uncertain of, I hit it again to be safe. Remember that heads, intakes, oil pans and such all have a specified sequence and/or a stepped torque process for tightening. I do the same for wiring harness connectors and vacuum lines... only it is a different chant.
    pittsburg,CA
    i found my self doing something close to your chant lol
    it was just a careless mistake , i torqued down the rocker arms to 24 ft ib ...and decided , " i dont need to turn the motor over by hand 720 degres , 180 will do " that little short cut cost me... o well , you live and you learn , and if you dont learn, you just end up F**kin up .
    but thats what fourms are for right ? to share mistakes and learn from others experience
    Pittsburgh
    2008 Hummer H3
    You should have the car tuned for the cam while you're @ it..
  1. Cylinder-Head Port Mold - Pour It On!
    Last Post: 09-13-2013, 12:40 PM
  2. intake mounting holes in cylinder head
    By yellow73 in forum Internal Engine
    Last Post: 08-19-2010, 06:14 PM
  3. Cylinder Head Port Design - CHP How It Works
    Last Post: 05-04-2010, 04:50 PM
  4. What is the runner length of the ls1 head's intake port?
    By 5.0stang in forum Internal Engine
    Last Post: 12-18-2007, 07:54 AM
