Results 1 to 15 of 15
Thread: Squealing Sound
02-15-2011, 06:40 AM #1Spaz is My Mentor
Squealing Sound
I changed both of my belts this week end and now I have an annoying squeal
that is on the passenger side. With headers its kinda hard to zero in on it.
When at idle I don't hear it, however when you rev up it gets worse. I'm thinking it is the tensioner. But which one? The Serpentine or the A/C?
Any help would be nice.
Thx.
02-15-2011, 11:52 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Usually after a belt change and you get a squeal as you describe...it is a pulley. Could be the tensioner.....gotta locate it....I use a 36" piece of a old broom handle. Sum bitch is better than a stethoscope.
02-15-2011, 12:57 PM #3
i was having this same problem recently and i changed ever pulley tensioner and belt that i could. come to find out in the end it was my water pump going out and dripping on the belts.
02-15-2011, 01:44 PM #4
02-15-2011, 01:59 PM #5Grand Imperial Wizard
No...on the bolts holding the pulleys.....put the end on something stable as close to the suspected part as you can...you'll know when you find it.
02-15-2011, 02:07 PM #6
02-15-2011, 02:21 PM #7Spaz is My Mentor
Let me see if I understand correctly. Take the broom handle or large screw driver, try to touch the bolt head while it is moving, if its bad it will wobble as the broom handle/screw driver gets close to it. Right?
02-15-2011, 02:32 PM #8Senior Member
- Nov 2006
- Indianapolis
No, you put one ear on the end of the screwdriver and the other end of the screwdriver on the suspect piece. Noise travels thru the long object and you listen and hear which one is making the noise.
02-15-2011, 02:54 PM #9
I have a phone on a 2 foot long piece of metal SOMEWHERE in this hell hole of a garage and sarge and the others are right.
I had a pully bolt come out at 85k miles on my Mountaineer 5.0 and the pully was nicking the fan. What a treat that was!
02-15-2011, 03:08 PM #10
02-15-2011, 03:23 PM #11
yep...redneck stethoscope. Being using them for years. Be careful though and don't get that shit in the belt and have it rip half your face off. It will work though. Since you say it does it on rev the first thing I would listen to is that tensioner while someone rev'd it up.
02-16-2011, 04:08 AM #12
02-16-2011, 11:48 AM #13
i recently had the same issue.. replaced the belt, tensioner pulley, idler pulley, then the whole tensions assembly.. still had a squeek.. ordered a goodyear gator back belt and it hasnt made a noise sense... may not be the problem with yours, but it worked for mine
02-17-2011, 04:52 AM #14
02-17-2011, 06:56 AM #15Spaz is My Mentor
Found the problem, both tensioners where bad. No wonder it was hard to locate. Both are changed and no more squeaks. Thx for the help.
Squealing belt
By charles129 in forum General HelpReplies: 10Last Post: 01-15-2013, 05:22 AM -
squealing trans/clutch
By jetaws6 in forum Manual TransmissionReplies: 17Last Post: 12-30-2010, 05:59 PM -
Squealing Monster clutch
By BlackSS1 in forum Manual TransmissionReplies: 6Last Post: 09-11-2010, 07:34 AM -
squealing brakes...
By 0rion in forum GTOReplies: 27Last Post: 03-26-2009, 07:03 AM -
Squealing pulley?
By 98ramairguy in forum External EngineReplies: 25Last Post: 09-05-2006, 02:52 AM
