Page 1 of 5 12345 LastLast
Results 1 to 20 of 94
    Retired Outlaw Sum Bitch
    Latest Oil Filter Comparison
    Guy spent some major time and money for this.
    http://www.gmtruckcentral.com/articl...lterstudy.html
    And no surprise to me which filter graded out highest.
    For the filtration testing, after each filter was disassembled and all measurements and construction was examined, the filtering media was cut into 70mm circles. These filtering media circles were saturated with heated oil and placed into a 70mm büchner filter funnel vacuum filtering setup. The filter funnel was placed and sealed on top of a thick walled vacuum filtering flask. The vacuum was provided by a vacuum pump which pulled an almost full vacuum (~14psi) which simulates the oil pressure of the engine, although its lower than what is typical for our setup (which typically runs between 20-50psi), but 14psi is still considered in the 'normal' range from GM, so it does provide an accurate comparison. The test oil was heated to between 90-99 degrees Celsius, which is approximately full engine operating temperature, and 100mL amounts were mixed with approx .250g of contaminant and mixed well. This mixture was then filtered through the oil filter media circles, this filtered oil was collected and re-filtered again through a separate 90mm büchner filter funnel using a standardized 90mm fine lab filter paper which filters 98% at 2.5µm. The excess oil was filtered through the testing filter paper and then photographed next to the correlating 70mm filter media circles using a fixed normal lens (35mm f1.8 lens on a 1.5x crop sensor Nikon D90 DSLR).
    And for those who need cliff notes.........
    The grading criteria was
    30um Filtering........Overall Build Quality.....Media Surface Area.....Media Volume....Price.
    And the top five are (Top First)
    Fram XG
    Mobil1
    Royal Purple
    Amsoil (Tie 4th)
    K&N......(Tie 4th)
    Bottom Five are.....(Worst first)
    Shell
    AC Delco
    STP
    ProLine
    Fram High Mileage
    Orlando, FL
    Mean Black
    Very nice info. Very nice of this individual to take the time and money to do it. Thanks for sharing.
    Great info! I do not understand how the Wix and Napa Gold filters received different grades. I thought they were the exact same filter. Last trip to the parts store I tried to get a Fram Extended Guard for our Durango and there was no such thing. I'll have to see who stocks them in our area or just start ordering ahead of time.
    Manufacturers build to customer specs specific. They literally are the same filter but have various miniscule differences. I get the Fram XG at WalMart.
    XG16 is for the 4.7L Durango. I looked up 2007....I dunno....
    yep...same here. Wally world carries them.
    I have oil and filter changes coming on the Durango and the Duramax tomorrow.....expensive day between the 2 of them because the truck is also due for a fuel filter.
    Guess I'll have to start buying Fram XG and quit buying Wix
    One constant in the business of auto parts/fluids is change.
    Member CompSyn's Avatar
    Pacific NW USA
    Post Initial comments:
    1) While it’s an interesting and well done test, some might argue that the industry standard for comparing oil filter efficiency is the ISO 4548-12.
    2) Some might also argue that perfect environment laboratory conditions lack the actual real world conditions experienced by an oil filter in real world driving conditions, e.g, engine vibration, road shock, hot and cold starts, etc.
    3) Latest oil filter cut always are nice.
    5) "Filteration and build quality are somewhat objective so you can make your own judgments"
    4) Amsoil EaO - highest grade for filtering, lowest grade for price, duh…
    CompSyn
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Fram XG
    Mobil1
    Royal Purple
    Amsoil (Tie 4th)
    K&N......(Tie 4th)
    Shell
    AC Delco
    STP
    ProLine
    Fram High Mileage
    This is the only one I've put on the car.
    I'm surprised there's such a big swing in fram products.
    The GC usually gets the fram, but wasn't so lucky for this change.
    Senior Member
    texas
    2000 formula
    got me a RP filter today
    park bench
    gmcheviac
    Rp atleast puts their sticker on one decent product
    Member El Toro Loco's Avatar
    Harlingen, tx
    pewter
    2001 Trans AM WS6
    ill be switching all the vehicles to Fram XG
    Quote Originally Posted by KMdef9 View Post
    We are only seeing good returns/quality with the Fram Xtended Guard at not the other Fram oil filters.
    Quote Originally Posted by CompSyn View Post
    CompSyn
    I agree man. But we must take this guys "test" for what it is.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    I am amazed that they would have both a filter in the highest category and a filter in the lowest.
    Have they always been like this? I realize they shift a few places up/down every year, but this is the first time I've looked at a study like this, for filters. Does that depend on how often a product gets redesigned?
    Constant change is the norm.
    Feb 2011
    Ohio
    2001 Z28
    I've always been sold on mobile 1 or k&n oil filters, its hard to believe that there is a fram filter that would be rated number 1. Only reason i say this is because thats all we use at work and the pro filters we get i wouldn't put on my bicycle. Just my honest opinion but take the guys research for what its worth and very nice info thanks for sharing
    No doubt. I myself bashed the shit out of Fram for a long time. But as I have said.....things change. AC Delco went the e-core route and I would not put one of those on my bicycle now.
    Feb 2011
    Ohio
    2001 Z28
    I think it would be a cool idea as well to see how the oils have changed in comparison as to what they us to be and to see if mobile 1 stays at number 1. Has there been a post on that? Also i didn't realize how shitty the delco filter had become
  1. Replies: 32
    Last Post: 03-11-2011, 05:36 PM
  2. A political comparison
    By pajeff02 in forum Political / Debate Forum
    Last Post: 04-19-2010, 05:34 PM
  3. Intake Comparison
    By mavrikZ in forum Firebird / WS6
    Last Post: 02-17-2006, 08:42 PM
  4. Intake Comparison
    By mavrikZ in forum Appearance Section
    Last Post: 02-15-2006, 08:47 AM
