Results 1 to 13 of 13
    Member turyg ls1's Avatar
    Apr 2010
    Clewiston,Fl
    2002 camaro ss slp #2582
    centerforce dual friction or ls7 clutch
    I will b ordering my clutch 2night but wanted some opinions from y'all. It's not my DD but my wife will also b driving it ... any thoughts well appreciate it..
    Too Old For Your Crap. kmassner's Avatar
    North Las Vegas
    2002 Z28 M6
    I just got the LS7 clutch put in yesterday. I like it a lot. It's a little stiffer than stock, but not much. I'm very pleased with it.
    Got mine from KY Speed.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    ls7
    Member youngrigo's Avatar
    Nov 2010
    Bay Area, CA
    2000 SS
    LS7
    1967 Camaro - LS1 T56 project
    2003 Z06 - Procharged and LTs
    2001 Honda Civic EX - DD
    2005 Kawaski KFX400
    2000 Camaro SS m6 - 523rwhp 468rwtq - (Sold)
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    i have the centerforce dual friction and have had zero problems and have put it through some serious abuse but I would probably say the ls7 as well.
    Junior Member BIG_MIKE2005's Avatar
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    Screw both those options, trust me the LS7 will eventually bite you in the ass. I jumped on one about 3yrs ago while my hydrolics were working fine, now my master is on the way out & the adjustable pressure plate on the LS7 assembly is stopping me from just installing a better master.
    Look into a Diamond clutch set-up, they are getting great reviews & have a non-adjustable pressure plate. Pricing is very good as well.
    If I had known & been informed of potiential future issues thankx to the adjustable pressure plate I would have avoided this set-up. That & once it does go, the LS7 pressure plate is all you can use with the required LS2 flywheel. So you cant just replace the pressure plate & disc in the future, you'll need a flywheel as well, stock or aftermarket your choice.
    Apr 2010
    Clewiston,Fl
    Well it's to late cause I ordered the center force.... btw thanks and I will look into that 1 later...
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    Yea, figured I'd at least throw this info out there since its just recently comming to light on other forums & drivetrain shops are backin up the bad news about the adjustable plates too.
    Apr 2010
    Clewiston,Fl
    Now that u mentioned that I just noticed its out there ...how did that happened?
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    That would be b/c many vendors were pushing these clutches as a upgrade from stock for the same price as a stock replacement when they hit the market. No one had tried & tested the adjustable pressure plates. But everyone knew it would work with a stock unit. So lots of people just like myself jumped on them & were still using a stock master.
    Then when it starts acting up & you start tryin to replace hydrolic components & nothing fixes it after a new slave & master you get to discover its the adjustable plate comming back to bite you. Some people have even tried installing another new stock master & it still not working properly.
    Supposedly the pressure plate can be reset but no guarentee it'll work. And you need a press to engauge all the fingers on the plate like a slave is pushing on it to get the blocks back to OE dimensions.
    Apr 2010
    Clewiston,Fl
    Oh ok I get it.. what do u think about the center dual clutch..?
    Jun 2006
    Skiatook, Ok
    1999 Trans Am WS6
    I had a Centerforce clutch back in my import days & it held just fine. In these cars I have seen them work on par with a stock clutch but not hold up too well on a car modded with H/C/I, but I have not personally ran a Centerforce clutch in a LS1 powered vechicle, only read reviews on them.
    Apr 2010
    Clewiston,Fl
    Well hopefully it works for me....
  1. FS: Centerforce Dual Friction Clutch and flywheel
    By John Ceta in forum Parts For Sale / Trade
    Last Post: 07-13-2008, 06:26 AM
  2. Centerforce Dual Friction Clutch FOR SALE
    By lindseyamaya in forum Parts For Sale / Trade
    Last Post: 05-07-2008, 04:59 PM
  3. Z06 Clutch VS. Centerforce Dual Friction
    By 99Firehawk in forum Parts Review
    Last Post: 03-06-2007, 06:50 PM
  4. Centerforce Dual Friction Clutch Assembly
    By kubio in forum Drivetrain
    Last Post: 09-30-2006, 07:40 PM
  5. Centerforce Dual Friction Clutch
    By BADBLUE02 in forum Parts For Sale / Trade
    Last Post: 03-07-2006, 02:02 PM
