Results 1 to 20 of 22
Thread: Old School chevy need help
02-09-2011, 03:27 AM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I have a 69 chevy truck with a 350 engine bored 30 over crane cam 278-467/494 lift, Rpm intake, 750 Holley carburator Vac.Headers,Stall and shiftkit in the 350 trans.The promblem I have had for a while is that the truck just want move out if you nail it to the floor at a stand still or below 50 mph It just sit there as if it has to make up it's mine to go.If I ease into it,it will do fine but nothing other than that.Tried changing carb,Disturator,wires, checked gaps on the plugs,and made sure there was a good 12 volts going to the disturator. What could it be? NEED HELP.
02-09-2011, 03:31 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Are you saying it "bogs" as in floods the bowls?
02-09-2011, 03:41 AM #3
^^ Agree, need more information. Does the engine rpm jump up when you stab it, but the truck does not move? Or, does the engine stumble or hesitate rather than rev up?
02-09-2011, 05:39 AM #4Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
02-09-2011, 05:45 AM #5Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
02-09-2011, 08:15 AM #6Junior Member
- Dec 2006
- Detroit
rust.....- '50 Chevy Styleline
It sounds like you need to change or experiment with the vaccuum spring that opens the secondaries. slow down the rate it open them.
02-09-2011, 08:19 AM #7
Could be a couple of things. When you depress the accelerator, the carb is supposed to give the engine an extra shot of fuel. I'm not a Holley fan, but my recollection is they utilize a power valve for enrichment that works off a vacuum signal. (Q-jets and Carters employ an accelerator pump that forces additional fuel into the engine).
If the power enrichment circuit is not set up properly, meaning your secondaries are opening and not enough fuel is getting to the cylinders in time, it creates a lean bog like you described. I believe that the Holley power valves can be "blown out" by a backfire and become inoperable. Again, Holleys are not my thing.
02-09-2011, 08:58 AM #8Grand Imperial Wizard
Take the fuel level sight port on the side of the primary fuel bowl off. Fuel should just "trickle" out....or not at all or gush out. If it is not coming out at all your too lean and gushing out your too rich. You should just have a trickle like I said.
But before I did that I'd check some obvious/basics.
Is your throttle opening up all the way? Is the throttle sticking maybe?
Pull the air cleaner and you'll see four little holes on the choke tower. They are the acceleration and idle air bleeds. Blow some compressed air into them to insure they are not clogged with crap.
Get ahold of a vacuum gauge. Check your manifiold vacuum pressure. I'd just replace the power valve as part of the troubleshooting. Jeff makes a good call there.
Let us know.Last edited by Sarge; 02-09-2011 at 01:10 PM. Reason: Old person moment :)
02-09-2011, 04:05 PM #9Impounded
- Apr 2006
- park bench
- gmcheviac
Is your detent cable adjust correctly? It will bog like a mofo trying to go wot in 3rd at 50. I would trade that 750 for a qood later model q-jet ('78 or so) or a 600 holley or carter if you're prejudiced against rochesters.. Even with the best tuning, a 750 won't be as responsive as the other carbs on a mild 350
02-09-2011, 06:03 PM #10Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Thank you all for your reponses I will be tryiing all of the things said and maybe something will get me back to the way it use to run.I tried a 650 double pumper That was brand new and I had the same thing happen. I have tried the 750 off my camaro and the same thing happen. the kickdown cable have been adjusted time and time again because I felt that was the problem, but the bog is still there.With the 650 there was no power valve to cause the bog, It flooded the engine when I floored it.But worked fine on my camaro. There is little difference between the cams truck 467/494 camaro 510/510.I feel that it's sometime thats going on with the truck it self.maybe it Is in the kick down cable. Still open to anyother ideals. I want to get this truck back to where it use to be. I have out run a lot of guys on my job and I want to keep it that way.The camaro have the same setup but a bigger cam as listed.
02-09-2011, 06:09 PM #11Impounded
- Apr 2006
- park bench
- gmcheviac
If it's not kicking down to second at 50, that's an issue unless you are running crazy short gearing. The bogging off the line is a tuning problem though. What heads, compression, and timing?
Secondaries could be opening way too soon
02-10-2011, 03:59 AM #12Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
02-10-2011, 02:11 PM #13Impounded
- Apr 2006
- park bench
- gmcheviac
get an adjustable timing light for sure. You could probably stand a few more degrees of timing if you're running premium. Maybe around 33-34. I would pick up a how to book on tuning holleys, the Cliff Ruggles q-jet book was a help to me for sure
02-10-2011, 03:18 PM #14
yeah i concur that it is in the tuning of the carb. a quick and expensive fix is just to swap to efi
02-11-2011, 03:20 AM #15Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
02-11-2011, 09:18 PM #16Impounded
- Apr 2006
- park bench
- gmcheviac
02-11-2011, 09:19 PM #17Impounded
- Apr 2006
- park bench
- gmcheviac
02-13-2011, 01:10 PM #18Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
After thinking about this and reading the post made my you all, I need to know one thing, Why did the truck still bogg with a new 650 Holley evendoe it was a double pumper? and with my camaro's 750 which runs great on the camaro, if it's a tuning issue, not saying it's not, but tell me how this can be.
02-13-2011, 01:18 PM #1911 years of bangin gears
- Jan 2009
- North Jersey
Brings back some memories of high school when a buddy of mine and myself tinkered with his dad's Dodge B250 Tradesman. We installed an Edelbrock Performer carb and it bogged. I can't remember if we swapped jets, but we changed the detent spring and he adjusted the timing. Woke the van up.
02-13-2011, 01:51 PM #20
Performance Driving School - Back To School
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-29-2011, 03:40 PM -
old school chevy power ie. 1928
By CTSV in forum Domestics and ForeignsReplies: 0Last Post: 03-30-2007, 11:06 PM -
Chevy Small Block Dyno Tests - Old School Meets New
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-29-2006, 05:40 AM -
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 11-22-2006, 08:09 PM
