    Member Dave-TransAm's Avatar
    Dec 2009
    Gilbert Arizona
    1997 Firebird M5
    stock gear length
    Does anyone know what the stock gear length is for my car? I'm going to the track tonight and last time I went, my car was shifting into 4th just before the finish. If I left it in 3rd until I cross the 1/4 mile. Would that take a little time off? I hit a 15.3 @ 94.3 mph. Thanks for the help.
    Aug 2009
    NC
    midnight blue
    2000 trans am
    I would shift it manually, just make sure you don't bounce it off the rev limiter!!
    Member TA98's Avatar
    Mar 2009
    Maryland
    shifting it yourself will slow you down. it will feel like the trans is sliping everytime you shift. just put the shifter in the "3" position and leave it there
    Indianapolis
    2000 WS6 6spd Hooker LT
    Quote Originally Posted by T/A98 View Post
    Why do you say that? I have always been able to manually shift my AT cars at the drag strip and they have always been faster that way. Now if the trans is already programmed to shift at the optimum engine RPM then manually shifting won't help.
    My 1998 AT Trans Am would upshift about 5600. If I manually shifted it just at/before the 6200 RPM cutoff, it'd be faster at the 1/4 mile by 2-3 tenths every time, and I'd gain 1-2 MPH consistently.
    But OP, you don't want to over-rev the engine!!! Find out what RPM is safe for yours and don't go past that.
    Mar 2009
    Maryland
    everytime i shift mine myself you can feel it hesitiate and slip for a second the shift
    I let the PCM shift our car at the track.
  1. stock push rod length?
    By third_shift|studios in forum Internal Engine
    Last Post: 05-08-2012, 08:07 AM
  2. stock length on pushrod
    By blownh2x in forum Internal Engine
    Last Post: 03-31-2009, 09:30 AM
  3. Stock Length LS1 Rods?
    By Patsy57 in forum Internal Engine
    Last Post: 05-06-2008, 11:14 AM
  4. stock pushrod length??
    By JattGunMan in forum Internal Engine
    Last Post: 04-10-2008, 09:04 PM
  5. stock PHB length
    By ninobrn99 in forum Drivetrain
    Last Post: 12-05-2005, 04:47 PM
