    Aug 2010
    Savannah, Ga
    Blue
    2001 TA WS6, 1995 BMW M3
    B-Quiet ultimate...
    Just installed B-quiet ultimate in the TA. There is definitely a noticeable difference in the acoustic level inside. I would recommend this to anyone that thinks that the inside is too loud.
    Member MeGoFast's Avatar
    Apr 2009
    Chitown Burbs
    2013 Camaro 2SS/RS 1LE
    I did my Camaro with it and very pleased with the results as well. Seems so similar to Dynamat but much much cheaper.
    Junior Member jcsauer3's Avatar
    Jan 2011
    Florida
    2000 Ws6
    How much does it weigh? and how much did you put in?
    Apr 2009
    Chitown Burbs
    B-Quiet Ultimate is 1.6mm (60mil) thick, weighs 0.35 lb/sq. ft. comes in 1 foot wide rolls and is available in 2 sizes - 12 and 50 sq. ft. rolls
    From their website it says a 12 sq ft roll is $55 and a 50 sq ft roll is $130/$120 if you buy 2 rolls.
    I used a 50 sq roll for the whole floors front and rear and rear quarters.
    The 2nd 50 sq roll is for my doors, you may be able to do the doors with a 12 and a 50 but its going to be close if you plan to do rear quarters. Or just buy 2 50's and have left over for other uses. No I do not have anything to do with this company or product. Just shopped around and this stuff seems so similar to Dynamat and much much cheaper.
    Jun 2006
    NY
    Chevy Camaro SS
    is it harder than dynamat to install
    Apr 2009
    Chitown Burbs
    I never used Dynomat but installing B-Quite was easy. Just cut it to size, remove the backing and place where you want and press it down all over.
  1. Quiet Ride "Quiet Riding Comfort Kit" - Corners, E
    Last Post: 05-06-2010, 04:31 PM
  2. Bassani Quiet Thunder... is it quiet??
    By jwblake2 in forum External Engine
    Last Post: 06-26-2007, 06:32 PM
  3. Been a little quiet in here...How is everyone?
    By Mr. Luos in forum Rocky Mountain Members
    Last Post: 03-04-2007, 11:24 PM
  4. It's quiet around here.......
    By Nastyfoot in forum Almost Anything Goes
    Last Post: 03-29-2006, 10:21 AM
