Results 1 to 10 of 10
Thread: air pump
02-01-2011, 08:19 AM #1REAPER Z28
- Apr 2009
- Tyler TX
Navy Blue Metallic/Black- 02 camaro z28/01 wife t/a
air pump
ok so i think my z28 is curse by the devil. No matter what i do the freaking service engine light wont come off
its been on since i both the car. First it was the 02 sensors (replace that) then it was the clutch switch (replace that) and now is telling me that my air pump is bad. I replace the air pump i also replace the relay switch but its still showing that is bad
any ideas on what it could be? before i take it to the shop to get it figure out?..
02-01-2011, 08:33 AM #2
What codes are you getting? Is the pump making noise when you turn the car on? It sounds like air vaccum pump for a few seconds.
If is not making noise have you checked the AIR pump fuse? Are you sure your check valves are not the issue? Check valves are known to cause trouble.
02-01-2011, 07:35 PM #3Senior Member
- Apr 2008
- Madison, WI
You should read the Secondary Air: Diagnosing and Removal technical sticky in this section
02-01-2011, 07:55 PM #4
02-01-2011, 08:04 PM #5
02-01-2011, 08:08 PM #6Senior Member
- Apr 2008
- Madison, WI
Glad to help a fellow enthusiast
02-04-2011, 07:47 PM #7
What I found to be the most common cause of the Secondary Air Injection code, when I still had my AIR system installed, was simple fouling in the check valve. I simply removed those at the exhaust manifold and the hose to the intake, ran some carb cleaner through them and reinstalled. I cleared the code with my programmer, but it never came back after I did this.
This is just my opinion, but unless you need the AIR or are keeping your car all stock as a collector, I would remove the system and have it tuned out before I paid anyone to repair it. Clearing out the check valves is very easy though, and has been the cause of every code I've seen in my or buddies' cars.
02-04-2011, 07:52 PM #8
i dont know if this will help you or not, but i pulled the whole air pump lines exc off my car.
i will give it to you if you pay for shipping. if it works out for you, you could take what you bought back to the store to collect some gas money. eveything worked fine while it was on my car which is an 02 ss.
pm me if you want it.
02-06-2011, 11:07 AM #9
02-06-2011, 11:09 AM #10
Oil pump ?
By Mich's04 in forum GTOReplies: 16Last Post: 10-13-2008, 07:39 PM -
air pump
By binnie2424 in forum Camaro / SSReplies: 12Last Post: 09-15-2008, 07:44 PM -
Power Steering pump leak?! new pump or seal kit?
By JehalinTA in forum General HelpReplies: 2Last Post: 03-18-2008, 11:05 PM -
air pump Q
By pipes_ta in forum Firebird / WS6Replies: 3Last Post: 10-14-2006, 08:25 PM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 10:55 AM
