    Junior Member blackTA6585's Avatar
    Florida
    1999 Trans Am
    M6 gto tranny fluid
    Where do you put the fluid in a m6 2006 GTO?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    There is a drain plug on the driver side of the trans. I think it takes Dextron 3 or 4. I can't remember.
    Junior Member MNGTO's Avatar
    Minneapolis, MN
    2004 GTO
    Factory fill is Dex III
    Junior Member SSG Duncan's Avatar
    Nov 2010
    Texas via Korea
    Yello
    2005 Pontiac GTO
    You fill via reverse sensor on the passenger side. use a pump or stick a hose through the shifter dust cover and into the fill hole. DexIII is the EOM but check with your parts store and they will hook you up with the equivalent.
  1. Question: tranny fluid
    By transamgirl89 in forum Automatic Transmission
    Last Post: 12-21-2010, 04:33 PM
  2. New Tranny Fluid
    By TyeMug in forum GTO
    Last Post: 09-03-2008, 01:16 AM
  3. What tranny fluid
    By 346ci in forum Automatic Transmission
    Last Post: 03-29-2008, 11:25 AM
  4. Tranny fluid?
    By Black02LS1 in forum Manual Transmission
    Last Post: 05-18-2007, 05:55 AM
  5. Whats the best tranny fluid?
    By Hawk241 in forum Automatic Transmission
    Last Post: 05-17-2007, 09:41 PM
