    Rancho Santa Margarita, CA
    2002 Trans Am
    Turn Signal Wiring Harness
    Hi everyone,
    Hope someone can help me out.
    I have been searching all over for a replacement turn signal wiring harness. This is at the bulb end. My driver's side turn signal/Day-time-running light is not working. I know the bulb is good because if I put the bulb in the passenger side socket, it works fine.
    My socket on the driver's side shows signs of over heating. I think that water got in there and it got all messed up.
    The parking light portion of the socket works fine.
    What I am trying to find is the socket with three wires coming out of it, so that I can replace my faulty one.
    Does anyone know where to find one of these?
    My vehicle:
    2002 Pontiac Trans Am
    Thanks
    Jim
    Bonner Springs, KS
    99 TA
    The socket is dorman p/n 85881. It is around $7-8 at autozone or oreily's, it is not listed as the socket for a t/a. I believe it is listed for an s-10, but it is the right one, I have a spare in my basement that I just double checked.
    You do NOT need to cut the old wires...the socket comes apart, just pop out the inner part then pull the pins and the wires slide out.
    Mine were alittle corroded, so I scrubbed them off and then reinstalled it with the new socket and pins.
    Also you might want to consider drilling a 1/4" hole in the bottom of the housing to allow water to drain and evaporate to prevent the socket from being damaged in the future. I did this to mine back in '02 and no problems since.
    2002 Trans Am
    Awesome.
    Thank you very much.
    I was dreading having to take it to the dealer to have them fix it for a couple hundred $$.
    Bonner Springs, KS
    99 TA
    no prob, good luck with the replacement.
    2002 Trans Am
    Got the part. The replacement procedure went well. I ended up cutting the wires from the old connector and used some wire taps to connect the new wires. Everything works great with one exception. The locking tab does not engage to hold the socket into the lens housing. I used some electrical tape to hold the socket in place so it doesn't twist out.
  1. New amber light harness and turn signal
    By donkill in forum Stereo and Electronics
    Last Post: 03-06-2014, 05:50 PM
  2. Turn signal?
    By GrapeApeTA in forum General Help
    Last Post: 01-23-2011, 11:14 AM
  3. Turn signal help
    By Blksilvr in forum General Help
    Last Post: 08-08-2007, 04:46 AM
  4. Turn Signal help
    By Blksilvr in forum Appearance Section
    Last Post: 07-29-2007, 08:07 AM
  5. turn signal
    By malibumaniac in forum Stereo and Electronics
    Last Post: 08-20-2005, 07:44 AM
