Results 1 to 11 of 11
Thread: Shifter problems
01-27-2011, 08:51 AM #1Junior Member
- Feb 2010
- North Carolina
Black- 2004 Gto
Shifter problems
Well I have a problem with my Hurst shifter sometimes its tight and doesnt move and the spring back motion is working!! Now its really loose in the gears i can move the stick, its def not tight!! Then when i put it in neutral it doesnt spring back or anything it stays where i pull it out!! Its very wierd it still shift its just loose and doesnt spring back! Im setup to take it to my mechanic monday to let him look at it, I was hopin some of you would have some ideas what it might be. I just installed the shifter in Decemeber and it has less then 2,000 miles on it!!
01-28-2011, 02:02 PM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Frankly there has been so many issues with the Hurst shifter I do not even now where to begin. You can Google and just read for a year.
01-28-2011, 03:42 PM #3Junior Member
- Feb 2010
- North Carolina
Black- 2004 Gto
Well crap, I had a B&M short throw and it broke so i went and bought a Hurst cause I heard good things. Now its causing me problems and now your saying that Hurst has a lot of Problems!! What would you recommend if I decided not to go back to Hurst??
01-28-2011, 04:21 PM #4Grand Imperial Wizard
GMM Rip Shifter or Billet Pro
01-28-2011, 04:39 PM #511 years of bangin gears
- Jan 2009
- North Jersey
Did you install the shifter yourself? And did you grease the nylon cup that goes into the shifter rail in the transmission?
01-28-2011, 07:58 PM #6Junior Member
- Feb 2010
- North Carolina
Black- 2004 Gto
Cammed -- No i didnt install it i had a mechanic that i trust do it... and he is going to look at it Monday for me. When i asked him about the nylon cup he said he greased it good, but the stick feels like it has no springs at all...
Sarge -- I will look into it those shifter thanks for the advice!!
01-28-2011, 08:09 PM #7
01-29-2011, 07:08 PM #8Junior Member
- Feb 2010
- North Carolina
Black- 2004 Gto
Sarge- Where would be the best place to get the Gmm rip shifter or the billet pro.... Which one do you use if you dont mind me asking??
Cammed- What kind of shifter do you have if you dont mine me asking, and what would you recommend??
01-29-2011, 10:35 PM #9
If you have the OEM one still you could slap that on and see if the shifter is even the prooblem. bf you buy more.
01-30-2011, 02:29 PM #10
02-06-2011, 07:40 PM #11Junior Member
- Feb 2010
- North Carolina
Black- 2004 Gto
Well Cammed thats what I have and its already broke!! So im goin to go with a Gmm Rip shifter and send my hurst back have them fix it and sell it!!
Sarge where is a good place to get the Gmm Rip shifter cause i've been looking and theres so many place to choose!!
Stock shifter vs Hurst shifter
By karpetcm in forum DrivetrainReplies: 1Last Post: 05-28-2009, 10:49 AM -
Factory hurst shifter & regular shifter?
By importssuck in forum External EngineReplies: 30Last Post: 10-28-2008, 08:21 AM -
t56 shifter ? wich short through shifter
By truckman in forum GTOReplies: 4Last Post: 07-26-2008, 06:59 AM -
5.0 Shifter w/ Lou's short stick or just 5.0 Shifter
By jrc1122 in forum Manual TransmissionReplies: 6Last Post: 07-14-2007, 08:14 AM -
Pro 5.0 shifter or B&M Short Shifter?
By fastz99 in forum Manual TransmissionReplies: 4Last Post: 04-12-2006, 09:31 PM
