Results 1 to 18 of 18
    Junior Member Suzaku's Avatar
    Jul 2010
    California
    1999 Firebird Trans Am
    Recommended Aftermarket Rear Control Arms
    I just found out that my stock trans am rear control arms are horribly bent like about 1-2 inches to the left? and I've been driving on them like that for damn near forever...
    What would be a recommended / best aftermarket control arm with the least wheel hop?
    Metco
    http://www.afterthoughtsauto.com/cam...trol-arms.html
    http://www.afterthoughtsauto.com/cam...-brackets.html
    or
    BMR
    ws6project.com/user_stor/catalog/product_info.php?cPath=235_23_232&products_id=3179
    or anyone with personal experience with another company with a better recommendation?
    Auto Painter RyanJM's Avatar
    Houston, TX
    I have UMI and they products are great and not too much money compared to others, you can get them direct or I actaullly ordered mine from WS6store since I was ordering other parts.
    I would order set with the panhard bar and just do it all at once.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Omaha, NE
    2000 Z28 Camaro
    I use the UMI as well with relocation brackets, i didn't see much improvement on my worn out nittos, but maybe I need to lower them to the lowest setting.
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    i went with BMR and got the relocation brackets (have not installed the relocation brackets just yet). i got the nonadjustable ones and they were a pain to install but i knew i was going going to take the time to try and adjust things ever. i'm happy i did it, one less thing to worry about.
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    i have the umi non-adust. LCA, and the relocation brackets set at 3", a non-adjust. panhard bar, non-adjust. torque arm, a spohn 1" rear sway bar with a umi aftermarket rear sway bar installation kit (for stock axles),umi heavy duty aluminum sway bar mounts, umi boxed weld on subframe connectors, and a strut tower brace...still need the front sway bar, but the car feels 10 times better than stock did...if you plan on lowering your car, get the adjustable panhard bar and torque arm
    culver city, Ca.
    Quote Originally Posted by allbaugh_04 View Post
    ...when i 1st put those brackets on, i put it on the 3" setting. then a little while later, i did the 2" setting just to see how it felt, and i went back to the 3" setting cause i couldnt stand the wheel hop anymore...
    Omaha, NE
    2000 Z28 Camaro
    Quote Originally Posted by godless-phoenix View Post
    I'll change mine then, just to see what the difference it might make.
    I haven't experienced wheel hop yet, even stock.
    Member TA98's Avatar
    Mar 2009
    Maryland
    we have the Metco ones on our 2011 5.0 but i was planning on getting the BMR's for my Trans Am unless i can get a deal on the Metco's from work.
    culver city, Ca.
    maybe ur just not driving it hard enough jk, hehe
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    +1 For UMI great products fast shipping friendly service just my 2cents
    Jul 2010
    California
    Thanks guys, I'll be getting the UMI ones then.
    What are the downsides of having adjustable control arms?
    Do the settings come loose when driving? Okay for strip?
    culver city, Ca.
    Quote Originally Posted by Suzaku View Post
    i would say the only downside too adjustable ones (besides price) is that the ride is probably to rough for street driving, but good for track racing though
    Junior Member new2dgame's Avatar
    Nov 2009
    Mandeville La.
    Jet Black
    1999 Trans Am
    Why do u need relocation brackets ?
    Greensboro, NC
    2002 Trans Am WS6 M6
    The biggest complaint with adjustable ones usually is the noise. The ride I don't mind but the noise can get old especially on long trips.
    culver city, Ca.
    Quote Originally Posted by new2dgame View Post
    you dont...BUT they relocate the part of the lower control arm that bolts to the axle, putting it at more of an angle, so there's more down force placed on the rear tires for better traction... and the relocation brackets for the rear sway bar are because i have a mac rear and cover "gurdle" and the stock location of the rear sway bar would hit up against the the thicker differential cover. putting longer endlink bolts and bigger bushing mounts for relocating the rear sway bar, gives better clearance for something like the situation i had, and or for aftermarket rear ends...
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Oops, forget to show sig
    Jul 2010
    California
    Ok, an update on the issue. I took a look at my car today with my brother who is really deep into the fairlady series and we discovered that my spohn adjustable panhard bar had come loose / adjusted incorrectly and had ended up pushing the rear end about 2 inches to the left.
    The control arms are perfectly fine, but I'd like to replace them anyways. Anyone have any experience with the UMI offset adjustable control arms?
    Marylandistan
    2001 Trans Am (sold)
    I'd get Spohn or BMR.
  1. Question: Aftermarket Control Arms or Stay Stock?
    By GatorSS in forum Suspension and Handling
    Last Post: 03-04-2011, 08:44 AM
  2. Aftermarket K-member, upper and lower control arms???
    By rll2 in forum Suspension and Handling
    Last Post: 02-13-2008, 08:10 PM
  3. 96 T/A rear end cover and boxed control arms.
    By fordwhupper in forum Suspension and Handling
    Last Post: 05-05-2007, 08:37 AM
  4. rear lower control arms
    By teal monster in forum Suspension and Handling
    Last Post: 01-02-2006, 07:39 PM
