    Dec 2010
    New Jersey
    1998 WS6
    T/A exposed 98-02
    Hello everyone,
    Now that im looking for a WS6 (which will be my second car)
    i want to know what has changed from
    98 to 99,
    99 to 00,
    00 to 01,
    01 to 02.
    i also want to know how to tell a true WS6 to a very well done clone WS6.
    i dont want you guys to think im a noob but i also tought this will help ,amy people.
    since my brand new Ford Raptor is being lemoned im moving to my favorite car in the world.
    TA WS6
    anyone selling a WS6 in the NJ/DE/NY/CT/PA/MD area?
    thanks in advance.
    Nov 2010
    Upstate Ny
    99 Formula
    the rpo codes will show ws6 best way to tell .
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    as far as i know, i know there's others who could answer better than me, but the 98-99 weren't that much different, the year 2000-2002 came with a different pcm than the 98-99's (i think)...and the 01-02's came with the LS6 intake and no egr, witch is a plus...i know there's a couple more differences, but im not too sure...too find out if its a real ws6 you look for the rpo code ws6 on the drivers door, thats the easiest way hope i helped some...
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    cam sizes were different post 2000 i think? smaller cam in the 01 and 02's but they had the ls6 intake. IMO id go with a 99 or 98 and just do an ls6 intake swap or an egr delete and tune it out.
    college station, tx
    sold: 1999 firebird
    1. Had different casting heads which had perimeter bolts and valve covers.
    2. Ignition coils were mounted to the valve covers one at a time.
    3. The water temp gauge actually works.
    4. Only LS1 year to not have an oil life monitor
    5. WS6s had single outlet exhaust (all others had duals)
    6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
    7. Only year that Purple, Gold, and Green were available
    8. Some very early Trans Am's came with LT1 style headrests
    9. Rear hatch release was poorly designed and often caused problems releasing mechanism
    10. Early model 98 Monsoon stereos didn't have capability to control 12-disc CD changer
    11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
    12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT faster than 2000+ cars
    13. 1998 cars had 28 lb fuel injectors from the factory
    14. 1998-2000 cars had a larger cam than the 01-02 cars
    15. 1998-1999 cars had more restrictive exhaust manifolds
    16. 1998-2000 cars had an LS1 intake with EGR
    17. 1998 and some early 1999 cars had blue outside rear view mirrors (Trans Am only)
    18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
    19. Last year F-body to use the old 15.5 gallon fuel tank.
    20. Only year LS1 F-body to contain a gas cap with a tether long enough to actually hang from the fuel door while open
    21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
    22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
    23. 1998 only cars did not have an idle adjustment screw on the throttle body
    24. 1998 cars have a completely different PCM from 99+ cars
    25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
    1999
    1. 1999-2000 cars switched to 26 lb fuel injectors
    2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
    3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
    4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
    5. 1999 cars continued the LS1 intake with EGR provisions
    6. 1999 cars continued more restrictive exhaust manifolds and larger cam
    7. Only year that Hugger Orange was available (Camaro only)
    8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
    9. Switch to larger 16.8 gallon fuel tank to meet new emissions requirements.
    10. Gas cap tether was shorter and could no longer be used to hang on the gas door when open.
    11. Company wide change added black boxes to record up to 5 seconds of data before a crash
    12. Rear hatch release was redesigned with stiffer spring that released the hatch better
    13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
    14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
    15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
    16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
    2000
    1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
    2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
    3. Added rear child seat safety hooks to interior per federal requirements
    4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
    5. Camaro's got redesigned 10-spoke base rims, and SS's came with new 10-spoke rim design
    6. First year of Monterey Maple Metallic paint
    7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
    8. Cloth interior cars got new rainbow colored cloth patterns
    9. Camaro's only got the Pontiac steering wheel with optional audio controls
    10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
    11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
    12. The last year a WS6 Formula was offered
    13. Starting 2000 intake lids contained a separate breather filter
    2001
    1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
    2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
    3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SS's
    4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
    5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
    6. WS6 cars had a redesigned 5 spoke rim which was more wavy
    7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
    8. Manual transmission cars all came with the Z06 clutch
    2002 - Last year of the F-body
    1. 35th Anniversary edition of the Camaro, and Collectors Edition Trans Am available
    2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
    3. 2002 cars continued with the LS6 intake, 28 lb fuel injectors and smaller truck cam
    4. 2002 continued the use of an LS6 block in some LS1 F-bodies
    5. A factory supported optional 345 HP option could be ordered from SLP
    6. Manual transmission cars continued use of the Z06 clutch
    7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Great info justin!!
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Great info justin!!
    He's good at copy and paste
    Differences between the f-body years
    MarioR93, I want to add, Pontiac offered a Formula WS6 and a Trans Am WS6. The LS1 Formula WS6 was only available for 3 years (98, 99, and 2000).
    college station, tx
    sold: 1999 firebird
    stealing my thunder
    Auto Painter RyanJM's Avatar
    Houston, TX
    I would just say find the best low mileage WS6 you can and don't worry about the year. The only true way to tell is the door code since a WS6 is easy to duplicate it's not really much of an upgrade and most are at least mildly modded so alot of the WS6 from it is gone.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    culver city, Ca.
    wow! alot more differences between the years than i thought
    Dec 2010
    New Jersey
    1998 WS6
    thank you everyone.
    this is one of the t/a's im going to checkout this weekend
    http://www.autotrader.com/fyc/vdp.js...standard=false
    http://delaware.craigslist.org/cto/2154168431.html
    http://delaware.craigslist.org/cto/2153638991.html
    http://southjersey.craigslist.org/cto/2147447641.html
    (red very clean)
    whats the best deal and what should i offer.
    not to interested in the blue with the vette wheels mostly interested in the red and blue one (first link)
    thanks again everyone
    Orig Regist: 9/98
    NE Indiana
    1998 Trans Am WS6 'Vert
    I may have missed it, but one thing I didn't see mentioned was that in '98, Monsoon was not available in a 'vert. '99 was the 1st year Monsoon was available in a 'vert.
    Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
    KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
    Link to Firebird Production Breakdowns
  1. Pop songs exposed
    Last Post: 04-03-2010, 11:59 AM
  2. Girl on FB just exposed guy from HS as gay pornsta
    Last Post: 10-05-2009, 04:59 AM
  3. Black Serial Killers exposed.
    By SLIM_DURST in forum Political / Debate Forum
    Last Post: 05-10-2008, 07:02 PM
  4. carlos mencia exposed...
    By Oldladykiller in forum Almost Anything Goes
    Last Post: 02-14-2007, 12:39 PM
  5. Barry Bonds is exposed
    By zleeper z in forum Almost Anything Goes
    Last Post: 03-10-2006, 05:08 PM
