Results 1 to 11 of 11
Thread: blown head gasket
01-16-2011, 08:53 AM #1
blown head gasket
well got in it this morning to got the store and started it up and white smoke comming out of the tail pipes soo time for me to do what iv been wanting to do anyways engine is comming out and ls6 intake,new clutch, headers, and maybe a cam of such
01-16-2011, 09:49 AM #2
01-16-2011, 01:43 PM #3
ok well after looking at this more closely i noticed a lil water about the #5 injector so i decided to pull the spark plug and well it was wet ok fine so i pull the other 4 and there all dry pull the other side all dry so my ? is wtf is going on here ?
01-16-2011, 02:58 PM #4
That's probably your cylinder with the leak.
Edit
Are you saying you also had water on the injector, I.E. on the out side of the engine? Kinda confused on your confusion lol. Also what was the plug wet with, fuel, oil, coolant? Can you do a compression test for us? Hope that helps.Last edited by Jay37; 01-16-2011 at 05:35 PM.
01-16-2011, 07:06 PM #5
the plug was wet with coolant jay
01-16-2011, 07:17 PM #6
01-17-2011, 03:05 PM #7
jay you where right it was the cylinder that was affected by it alright so much so that the sleeve and the water jacket on #5 was cracked so block= junkyard
01-17-2011, 04:28 PM #8
The cracked cylinder Attachment 20233
01-17-2011, 04:30 PM #9
Any one else see what I saw? I might of finally lost my last marble.
RUDE, CRUDE, AND SOCIABLY UNACCEPTABLE.
01-17-2011, 04:39 PM #10
thanks jay im still in ahh about all of this i didnt think this was going to be the result of it
01-17-2011, 05:03 PM #11
Well Mr. Badass I will make the same recomendation I do (and Mr. Grigo is the one that sold me on it.)all the time. Steel block, 5.3 heads, all the other variables will be dependent on money, your own capabilities, and how anal you are.
I currently am building one and 150 for the block and 200 for the heads. If I was younger neither one would go to the machine shop.
Help: Possible blown head gasket????
By youngrigo in forum Internal EngineReplies: 34Last Post: 01-26-2011, 08:55 AM -
STS blown head gasket?? What head gasket
By 2000sts in forum Forced InductionReplies: 4Last Post: 08-26-2009, 02:23 PM -
Question: Blown Head gasket
By Orrin's Z in forum Internal EngineReplies: 7Last Post: 10-10-2008, 05:52 AM -
Blown head gasket and cracked head in my '00 5.3 Tahoe
By SScatman02 in forum GM TrucksReplies: 4Last Post: 11-13-2007, 08:58 PM -
blown head gasket!!! help!!!
By tonyjnjz in forum Almost Anything GoesReplies: 28Last Post: 10-12-2007, 09:28 AM
