Results 1 to 20 of 27
    Jan 2011
    Baton Rouge,LA
    2002 trans am ws6
    Question How to replace subs in sails
    I just want to keep the stock speakers but my sail subs sounds bad is this a easy replace. Can someone give me some help. Is it as easy as popping the cover of and getting a new one and putting it in its place???? Thanks
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Short answer yes. You can get to the screws after you pop the cover just be careful not to break the tabs on the cover.
    phoenix
    04 2500 4x4 crew cab
    If you are replacing stock, you will want to match the ohms of the replacement to the original. And I think you have to take the sail panels off to get to the screws. Pop the speaker cover off and look.
    Quote Originally Posted by superman63 View Post
    If using stockers, yes it is. And, you can get to them fine by just removing the cover. At least that is how it is with the Camaro.
    Just be careful when taking the screws out so that the clips don't fall. You'll never get them back if they do. Ask me how I know
    Jan 2011
    Baton Rouge,LA
    2002 trans am ws6
    Thumbs up thanks
    thanks for the info... I think I know how you know lol.... I guess I got to go to dealer to get the speaker or do y'all know of where I can get a good one??? thanks
    phoenix
    Junkyard would be cheaper.
    Not sure off hand where to buy stock speakers new. Although, if you could find them new they would be a pretty penny. ebay is a good place to check for used though.
    I know that there is a company that is supposed to make after market speakers that go with the Monsoon systems in our cars, but can't remember what their name is.
    Maybe someone else will remember and point you in the right direction.
    Junior Member jmro's Avatar
    Jun 2009
    North Alabama
    nbm
    2002 Camaro Z28
    I don't think it is just one company that makes them,If i remember correctly they have to be 2 Ohm. Yes all you do is pop that the cover of and unscrew. The only issue is if the new speaker has a bigger magnet on it then you need a spacer ring
    **Te@M fBoDy** fbodyNATION's Avatar
    Nov 2010
    The Woodlands,Texas...N.O.
    Pewter Metallic
    2000 Pontiac Trans Am WS6
    what aftermarket speakers have you guys used? because 1 of my sail speakers is blown, oh yeah my car came with the monsoon system if that makes a difference
    phoenix
    i ripped all out,and did polk. awesome.
    Nov 2010
    Pewter Metallic
    Quote Originally Posted by az gt eater View Post
    you even replaced the speakers on the back deck?
    phoenix
    Everything. I thinl I put 4×6's in the back.
    Nov 2010
    Pewter Metallic
    thanx i'll make a note of it im thinking about changing mine
    Member wenn_du_weinst's Avatar
    Aug 2008
    South Dakota
    should be 2 ohm 6.5'' right?
    I would wait for these to come out if I were you
    probably going to have to space them out little bit, I'd post their phone number but I don't think I can here since they arn't a sponsor
    Houston, Texas
    2000 C5 Torch Red
    I can't remember the exact unit, but mobile audio gouged me when I first got the car for new sail panel speakers. They were a 2ohm Kenwood that bolted in without removing the interior trim. Sounded great too.
    I'm thinking those won't fit... That's a lot of magnet.
    Aug 2008
    South Dakota
    not sure been a while since I sold my ws6 so can't measure
    Junior Member paulyc's Avatar
    Dec 2010
    ny
    bright red
    does not seem like we have much of a choice.like the stock radio but these sail panel speakers stink..
    Junior Member suvettetexas's Avatar
    Feb 2011
    wylie,texas
    2002 firehawk
    Quote Originally Posted by jmro View Post
    CHECK out KEE AUDIO, he has everything you need for complete replacements, that what im going to use when i replace mine....Great prices also...
    Feb 2011
    wylie,texas
    2002 firehawk
    Sorry i replied/quoted the wrong post, but if you are still looking for replacements try a place called KEE AUDIO, he specializes in F-body audio stuff, top notch and good pricing as well.
  1. write up: How to replace the stock subs with eu700s
    By third_shift|studios in forum Stereo and Electronics
    Last Post: 09-03-2014, 05:33 PM
  2. Cap'n Crunch sails into obscurity
    By BdAsBrd01 in forum Almost Anything Goes
    Last Post: 03-10-2011, 01:42 AM
  3. Question: What 6 1/2 inch subs to replace the stock Monsoon?
    By thomasterrible in forum Stereo and Electronics
    Last Post: 07-11-2010, 11:04 AM
  4. what to replace 6.5" stock subs with
    By gfeller2006 in forum Stereo and Electronics
    Last Post: 08-16-2008, 09:11 PM
  5. stealth box, or replace sails w, eu700s?
    By MnLS1 in forum Stereo and Electronics
    Last Post: 03-12-2008, 08:11 PM
