Results 1 to 20 of 20
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    New V6 camaro can run
    http://www.dragtimes.com/Chevrolet-C...lip-21158.html
    just look at this link i never thought id be envious of a 2010 V6 camaro
    Pittsburgh
    2008 Hummer H3
    Bottled 660! The 2011 Camaro 3.6l DI DOHC 60*v6 N/A has more base hp than a base ls1.. @ ~315 vs ~305..
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    They are just so big i cant get over that fact lol
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Too fricken heavy.. That engine should have been a 4th gen option or @ least a retuned lq1 instead of the all iron 3800 @ only ~200 crank..imho
    Junior Member Camar0's Avatar
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    The 2010 has 312hp also. GM didnt release the camaro sae numbers until mustang announced their numbers. The 304 hp was the llt motors rating in the cts.
    My '10 M6 LLT did 273 rwhp 250 ft lbs on a dynojet with a k&n drop in and stock SS cans. A6 LLT did 246hp and 245 ft lbs if i remember correctly. A 100% stock a6 l99 '10 camaro did 324hp 348 ft lbs about an hour before me. All runs were same day/same dyno.
    Hardest part is tuning is only avail from Vince/trifecta. No hptuners/efilive/diablosport etc.. Also seems to have some nasty torque management hidden in the computer. Down the road these coukd be killer bang for the buck if they get a few kinks worked out.
    Thats ROD1 drag slip. That run got him on the home page of camaro5.com. Im pretty sure the build was fairly cheap for the results. Nos, skinnies, drag slicks on z06 wheels, used ss exhaust, cai.. Pretty impressive results! V6 is 3700# though vs 3440 for an 02!
    Pittsburgh
    2008 Hummer H3
    The 3.6l dohc v6 has the potential to bring an aftermarket to the older LQ1.. Fingers crossed!
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Camar0 View Post
    304hp was also the number thrown out by the prototype testers.. My guess is just as the LQ1 proto was rated @ far more than actual production, that the 3.6l was prolly also producing more than the actual production engine numbers. But 273 rwhp puts you ~ 304 crank or so with drivetrain loss percentage...
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    "The 304 horsepower in the 2010 Camaro was actually a conservative rating on our end," Tom Sutter, GM V6 chief engineer, said in today's press release. "But we knew already that this award-winning engine produced at least the amount of power we stated, but now we've gone the extra step in certifying the engine for this application and have verified an additional 8 horsepower."
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    What are your plans for your 10 ?
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    Sweeeeeeet!!!!
    LLT is getting replaced with the LFX @ 325-330hp!!!!!!!!!
    The new engine option description is: "LFX 3.6L SIDI, DOHC, VVT, E85 MAX, Alum GM"
    The LFX should displace 3.6L, like the current V6 found in the Camaro. And it's packed to the brim with advanced technologies like Spark-Ignition Direct-Injection, Dual Overhead Cams, Variable Valve Timing, and E85 capability!!
    Those are the hard details...but a little research raises some other interesting points. It is likely that the LFX is going to build on the innovations of the 3.0L LF1 V6 found in vehicles like the Cadillac CTS, SRX, and Chevy Equinox. That engine features a composite intake manifold, integrated exhaust manifolds and optimized NVH/airflow treatments.
    When the LLT was transplanted from the CTS into the Camaro, it picked up 8hp, or 2.6% because of different intake/exhaust efficiencies. The LF1 produces 270hp in 3.0L form in the CTS. If we scale up the displacement of the 3.0L engine to 3.6L, and use the same 2.6% power increase as the LLT, estimates have the new LFX producing anywhere from 325-330 hp when used in our favorite pony car!!
    Here's some interesting documents on the LF1 (current CTS/SRX/Equinox engine) for your reading pleasure:
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    None, I sold it back. Had transmission problems. Theres a thread on c5 where 65% (100+ members) are repoting the ay6 binds or grinds and 5 have gone lemon so far. I would have to shift to third before i could get first at a stop sign.
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    I'm thinking a 2011 camaro can be my daily now that i know there is actually potential
    Pittsburgh
    2008 Hummer H3
    Nice. Sounds like my father in laws Ford Ranger.. I guess GM strikes again on first year bugs.. Most first year cars have some issues tho.. Guess we'll see how it goes...
    Figures just when my horse comes to town..
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    Wait for a '12 if you can. It will use the e39 ecm instead of the bosch unit. Then you can use hptuners which means hello boost!!!! They are expecting a 2.25 release date on this. The bosch unit isnt even on their backburner. You can run boost now but its a mail order tune instead of a software your speed shop uses. Plus youll get 18hp for free out the gate!!
    Honestly the car is amazing except for the trans issue i had. Its not a Gm issue as much as its the transmission maker - aisen's fault imo.
    Paint on the 2010 and 11 are extremely thin and chip super easy. Wait for a late build 11 or 12 model unless you like huffing the touch up paint! Not trying to act like i know it all.. Just want to share exp and help others get the most for their buck!!
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Not @ all.. It's nice to have another v6 guy around..
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    14.35 was my best 1/4 if your interested . Thats with a soft launch to avoid wheelspin. DR would have hit 13s i think.
    Oct 2009
    pasadena md
    Blog Entries
    2
    2002 SS Camaro
    So are you going to get a new camaro again?
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    No plans currently..
    If i do ill save enough to pay cash but only if they get rid of the AY6 or give the a6 v6 a posi and use the e39.. Then id get anpther '12 v6. Otherwise get an 11 or 10 v8.. Or just build a 60s muscle car. Long story short ... Nothing soon :-/
    Pittsburgh
    2008 Hummer H3
    I think so too.. Guys with completely stripped down bolt on 3800's are hitting high-mid 13's..
    Totally gutted a 5th gen v6 would be a menace on the streets and the track imho..
    Oct 2010
    Indy
    IBM
    2010 Camaro LS
    LLT in a 3rd gen would be amazing!
  1. 1967 Chevrolet Camaro - Classic Camaro With A Big-Inch Punch
    Last Post: 04-06-2012, 05:10 PM
  2. 1999 trans am, 1995 z28 camaro, 1979 z28 camaro for sell!!!!
    By poneykiller2k4 in forum Vehicles For Sale / Trade
    Last Post: 08-11-2007, 06:12 PM
  3. FS 97-02 Camaro Taillights/Ebony TTop shades/Camaro 35th model car
    By nhra-trans-am in forum Parts For Sale / Trade
    Last Post: 08-01-2007, 12:34 PM
  4. Replies: 1
    Last Post: 05-10-2007, 04:03 PM
  5. Replies: 19
    Last Post: 01-12-2007, 12:52 PM
