Results 1 to 20 of 27
    Junior Member Steve's LS1's Avatar
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    Question 98 camaro build up
    hey all,
    im building up my first ls1. and i have no idea on what to get with the cam im wanting to run. the cam i want to run is the T-Rex cam from thunder racing these are the specs 242/248 - .608/.612 - 110 lsa. now i kno i need to get valve springs. im gonna go with comp cams with them with 650 max lift. long tube headers. now what im asking you all about is, what else do i need to get for this build up. would i need to get the following: oil pump. timing chain. push rods. intake. throttle body. lifters. stuff like that??? or is there a more radical cam for a stock ls1? i just wanna shove the biggest cam possible in this camaro. with out gettin in to the core.
    thanks
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Some will suggest a stronger rearend if you haven't made the upgrade already. All those engine mods mean nothing if the rear grenades.
    Veteran Blackbird WS6's Avatar
    van down by the river
    street car? what trans? M6 or A4
    that alot of cam thats why i ask...yes you will need what you stated BUT the lifters should be fine unless you want to replace them
    you also need a full exhaust setup and a good set of heads to make all these things
    worth a dam and a stall if you have a A4...dont forget a tune when all said and done
    and a rearend if your M6....with A4 it will hold until it breaks
    Junior Member blackmagicturbo's Avatar
    Jan 2011
    Ventura, ca
    bleen
    2000 SS
    Patriot "gold" double springs are what i use and have used in alot of builds,, definitely gonna need some good pushrods ,maybe some ls2 lifter trays.. double roller timing chain (not a big fan of single roller with big cams) but people use ls2. rocker trunions upgrade a must... Sounds like a fun build !
    Member youngrigo's Avatar
    Nov 2010
    Bay Area, CA
    2000 SS
    ^^^^ What they all said in regards to parts.
    But have you driven a car with a cam that big in a LS1? Thats not really a street friendly cam. You will def need gears other wise its going to feel like a dog down low. That cam really doesnt come alive until the higher RPMs.
    I guess the question is, is this car going to be a track car or street car?
    1967 Camaro - LS1 T56 project
    2003 Z06 - Procharged and LTs
    2001 Honda Civic EX - DD
    2005 Kawaski KFX400
    2000 Camaro SS m6 - 523rwhp 468rwtq - (Sold)
    Quote Originally Posted by youngrigo View Post
    agree...
    Member cancam99ss's Avatar
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    Subscribed.... I wanna build my 99 Camaro
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    Quote Originally Posted by Blackbird-WS6 View Post
    its gonna be a track car. the car has the m6 in it. well i have headers and gonna get a 3" custom exhaust nascar style for it. and what heads do you recommend. i wanna run 456s but im not sure. what you think?
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    no i havent but im not really worried bout it. its not gonna be street'd tht much. i was thinkin 456s but not sure any input? and i def. dont want this camaro to run doggish. and if i gotta run it in high R's no problem =)
    and to your question its mostly gonna be a track car.
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    Quote Originally Posted by blackmagicturbo View Post
    ok, thanks ill look into that stuff. i just wanna throw good parts into it. not wanting to cut corners on a motor that is gonna be put threw its paces. ya know? lol
    Nov 2010
    Bay Area, CA
    2000 SS
    I have a buddy with that cam and ran 11.5 @ 125 cam only (Obviosly bolt ons too)
    But he runs it with 4.56 gears on a 28in tall tire. Its a good cam for the track but not that good for the street!
    yea with a cam like that you want a high gear and it being a track car is doesnt really matter about how drive-able it is...you also want a 9in rearend, dont waste your money on a 12bolt
    you also are going to want forged internals for your engine if you want a "track car"
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    yea with a cam like that you want a LOW gear and it being a track car is doesnt really matter about how drive-able it is...you also want a 9in rearend, dont waste your money on a 12bolt
    Fixed
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    was it a m6? i was told that runnin 456s would make first gear useless.
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    im not gonna tear into this motor to do all that. im plannin on building a stroker. but i havent looked all that into it yet.
    Quote Originally Posted by Steve's LS1 View Post
    ummm....OK!! lol
    i hope you know most strokers are forged internals and if you stroke it, its not an ls1 anymore lol
    Dec 2010
    Southington, Ohio,
    98 Camaro Z28
    ummm....OK!! lol
    yeah i knew that. but i plan oin gettin the lsx block from summit racing. and see what i can all do with it.
    Nov 2010
    Bay Area, CA
    2000 SS
    Ya its a m6 but he is also running a tall tire. 28in compared to the stock 25.5in
    ummm....OK!! lol
    LS1383
    LS1383
    cool, i got a LS1408
    check with Texas Speed & Performance before you go to Summit
  1. Help: 1994 3.4L camaro build
    By adrenalinejunkie in forum V6
    Last Post: 10-08-2016, 05:27 AM
  2. 68 Camaro TT Build
    By BrianMoseley in forum New Member Introductions
    Last Post: 06-18-2014, 10:31 AM
  3. Wanting to build a 4th gen Camaro.
    By Rabble in forum Camaro / SS
    Last Post: 02-23-2011, 06:01 AM
  4. 02 Camaro build
    By 02Sweet in forum Member's Rides
    Last Post: 08-06-2010, 12:09 AM
  5. 69 camaro engine build
    By 69camarokid in forum External Engine
    Last Post: 08-15-2005, 05:35 AM
