Thread: cd player fit
01-05-2011, 08:56 AM #1
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
cd player fit
so im looking at getting the JVC Arsenal KD-A815 for my 2000 ta.
it says when i go to checkout
"What you need to know:
* Extension kit -- when installed, the radio will protrude from the dash by 1/2".
* Unbolt or cut out the factory stereo's rear support bracket to make room for your new receiver."
does this mean it will stick out of the front a half inch if i dont cut the little bracket out, or it will stick out even if i cut it out.
01-05-2011, 07:40 PM #2
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
your correct on the stereo sticking out if you dont cut out the rear support. they make adapters that stick out like 3/4 of an inch and will allow you to install the stereo with no modifications, but in my opinion they look dumb sticking way out like that. i cut the rear support out of my deck support and installed a flush mount and i like it that way
01-05-2011, 08:05 PM #3
The bracket is easy to remove. I took pics when I did my Double DIN install:
Step 1.
Remove radio. You'll need to cut out the plastic tray, but that is real easy with a Dremel and a cut-off wheel.
The removed tray and my sexy hand.
Step 2.
Bend this bracket out of the way. I pushed it down and this is what I zip tied my PAC unit to that makes the steering wheel controls work with the Kenwood.2000 Pontiac Firehawk #0041 of 742
01-06-2011, 06:48 AM #4
01-06-2011, 06:50 AM #5
One thing I would suggest is to make sure your brackets are sturdy. I made my first set out of sheet metal that was too thin and went back and redid them afterwards.
.rar player anyone??
By nitrox28 in forum Computers / GamingReplies: 10Last Post: 08-10-2009, 09:21 PM -
help with cd player
By LT1 > LS1 in forum Stereo and ElectronicsReplies: 5Last Post: 07-11-2008, 11:10 AM -
Cd Player anyone???
By JoshieDoom in forum Almost Anything GoesReplies: 0Last Post: 01-13-2008, 06:45 PM -
Looking for CD Player
By marbalizer in forum Stereo and ElectronicsReplies: 1Last Post: 01-14-2007, 04:55 PM -
MP3 Player
By SamD_Ind in forum Stereo and ElectronicsReplies: 27Last Post: 06-26-2006, 10:59 AM
