Thread: Borg warner T-56 Power Handling
08-24-2005, 12:28 PM #1
- Michigan
Green- 1993 Pontiac Trans Am
im running a stock 93 trans am with a six speed borg warner t56. my goal is to have about 450-470 horse in mods can my transmission handle it
08-24-2005, 12:36 PM #2
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Your going to have your shift forks upgraded and your synchronizers upgraded. If not you will tear the transmission out.
08-25-2005, 02:23 AM #3
- Michigan
that makes sence but everything else will be ok like the gears and would my rearend be able to handle it
08-27-2005, 09:57 PM #4
the 10 bolt is weak and will blow itself away with just a set of slicks
08-30-2005, 12:21 PM #5
- metro Detroit area
Your T56 was rated at 350-ft-lb if it is the 3.36 low gear ratio unit and 400 ft-lb if it is the 2.97 low gear unit. It will need the iron 3/4 fork and a synchronizer upgrade to be more"modern" If you don't bet the xxx out of it, you will be ok trans -wise.
Tips for adjusting handling & handling bias
By Intrepidman in forum Suspension and HandlingReplies: 5Last Post: 05-22-2010, 04:34 AM -
01 Z28 Handling
By karpetcm in forum Suspension and HandlingReplies: 1Last Post: 07-25-2009, 09:51 PM -
Handling
By c5z28 in forum Suspension and HandlingReplies: 0Last Post: 12-02-2008, 12:19 PM -
tremec vs borg warner
By luciangage in forum DrivetrainReplies: 2Last Post: 07-23-2007, 05:06 PM -
Would like better handling
By Black Dragon in forum Suspension and HandlingReplies: 13Last Post: 10-19-2005, 08:05 AM
